SmartThings app: Can't divide rooms in robot vacuum map
I want to divide the rooms at the locations marked on the map to create a “Hallway” room, but it’s not letting me do the divider here. It throws an error that says:
Small rooms can’t be divided.
The rooms that I’m dividing (Living Room and Master Bedroom) are by no means small.
Is there a way around this?
Combine the living room with the master bedroom and then cut exactly where you put the red lines
Didn’t work… and now I have to make a brand new map, because I can’t separate the master bedroom and the living room via the hallway. I’m getting the exact same error message. I’m thinking it just doesn’t like it if the lines are too short.
Tagging @SamsungZell
Got it back to almost exactly how it was before. Still divided down the middle of the hallway between the bedroom and the living room. I’m just going to leave it, because I don’t want to mess it up again.
I kind of miss the roomba software. Rooms were created by placing and removing dividers. You could place dividers anywhere you wanted.
