SmartThings ADT Door and Window Sensors $4.99 at Amazon
They are reduced to $4.99 as Add on Items. If you have the ADT system I would grab a couple as it seems something is going on with them and they may stop selling them. I bought the max of 6 to have as spares.
Requires an SmartThings ADT Security Starter Kit (F-ADT-STR-KT-1). Will not pair with SmartThings Hub nor any other ADT panels
Thanks I probably should have mentioned that.
Smartthings ADT sensor.
Will not pair with Smartthings, nor with any other ADT system.
Sometimes, the jokes write themselves.
As a corollary, will existing ADT Pulse sensors pair with the ST-ADT hub? Just dropped ADT Pulse and wondering if I should replace the door sensors or if they will be picked up if reset.
No only the ADT SmartThings sensors will work with the panel to set off the Alarm. Other sensors will pair with the SmartThings side of the hub but they can not be used to trigger the alarm on the panel.
