SmartSense Motion Sensor
I recently bought the newer model of the SmartSense Motion Sensor to keep an eye on the house and temp. I setup an action to turn on a fan when the temp goes above a certain temp and have not been able to get it to work. Anyone have any ideals on how to fix this? I’ve tried IFTTT and had the same problem.
@techy87
First thing - Does the temp on the device actually get higher (or lower) than threshold set in the app? I just want to make sure you aren’t determining temperature against one device but triggering against a different device.
I’ve been playing around with different set thresholds within the app and it still never kicks on. I think its currently 67 in the room that I have the sensor in and the app is set to turn on the space heater if it gets lower than I think 60 right now (again trying to get it to kick on) and still have no luck.
67 is not lower than 60. Did you mean higher then 60 ?
