Smartthings power outlet - dashboard pane - showing wattage
Hi - On the smartthings (new) app - home “dash” page - I have an outlet that I’d like to see the wattage of without having to press the tile to open to see its value. It currently just has a power button and indicator on but nothing else.
Is this possible? How would I go about showing that data. Can I add some parameters to a custom device handler to do this - I’d like to retain the existing button/display of the active switch state too.
This is the topic what you should read along:
And I believe what you want is currently not possible. But if you will read the OP of the topic, you will see most likely what you can do.
