Smart Home Monitor- Status Notification
I’m trying to figure out if there is a way to receive a notification when the status for the Smart Home Monitor is changed. IE: I arm the system, I would like a push notification so that way others also monitoring will get a notification it was armed. If my wife or kids disarm the system, I get a notification that the system is disarmed.
I’ve clicked on everything and can’t figure out if this is a feature or if there is a way to make it happen.
Thanks in advance!
Create a routine to change your SHM mode and then have that send you a push notification.
do you really want a notification every time the SHM status changes? it can become annoying. but id say do with Core
You should be able to do it in webCoRE by coding a piston.
Thanks for the advice. I’m going to set a routine as a quick fix and work on the Core solution.
