So, I bought a Shelly dimmer https://shop.shelly.cloud/shelly-dimmer-wifi-smart-home-automation#58 and has plugged it in.
Everything works fine in the Shelly app, but…
I can’t figure it out to get it to work in SmartThings…
I’ve tried a few device handlers but I can’t find any that is specific for the dimmer ?
I have put in the ip and channel numbers and I can see the Shelly in SmartThings app but nothing works.
Any ideas ? Someone else that has this problems ?
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:29: debug Using IP 192.168.2.196, PORT 80 and HEX ADDRESS C0A802C4:0050 for device: ef64174b-2250-4d7d-86e6-28ad3c686c6b
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:29: debug Refresh - Getting Status
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:05: error java.lang.NullPointerException: Cannot get property ‘ison’ on null object @line 100 (parse)
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:05: debug null
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:05: debug Data
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:05: debug Parsing result index:2B, mac:84F3EBDB2CCE, ip:C0A802C4, port:0050, requestId:e0ca24af-bc46-4ed3-8d60-6c206891bc73, headers:SFRUUC8xLjEgNDA0IE5vdCBGb3VuZA0KU2VydmVyOiBNb25nb29zZS82LjExDQpDb250ZW50LVR5cGU6IHRleHQvcGxhaW4NCkNvbm5lY3Rpb246IGNsb3NlDQpDb250ZW50LUxlbmd0aDogOQ==, body:Tm90IEZvdW5k
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:04: debug Using IP 192.168.2.196, PORT 80 and HEX ADDRESS C0A802C4:0050 for device: ef64174b-2250-4d7d-86e6-28ad3c686c6b
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:03: debug Calling /relay/ with turn=off
ef64174b-2250-4d7d-86e6-28ad3c686c6b 12:27:03: debug Executing switch.off
You might want to search the Community for others trying to do the same thing. Here’s a good start:
I was wondering if anyone has tried integrating the new Shelly wifi devices into smartthings? https://shelly.cloud/
There is a rest API, and as they are ESP8266-based there is also the possibility of flashing new firmware (similar to Sonoff devices) and bypassing the Shelly cloud altogether. In particular the Shelly 1 relay is very compact and could be useful for installing in switch boxes and/or a ceiling rose. the smoke detector also looks like it could be good.
Yeah i´ve tried looking like a maniac
But no luck with the question that I got.
Are you trying to use your Custom DTH or the native integration? To add them through the official support channel, you have to go into the new app, press the +, then select device, then select Shelly from the list. That is how you add them with the native integration. If you are trying to use a custom DTH then you should post on the thread where you found the DTH.
Oh haha it works now! I was using the old app to add the device and thought I had to use a DH to integrate it…
So my bad, and thanks it works now haha
