Hello,
Some of my Aeon Micro Switches don’t update the hub when they are manually switched. I contacted Aeon support and they responded with:
If it is possible to make parameter change to the DSC26103, then set this parameter setting:
Parameter 80 [1 byte]: 1 or 2
This should allow automatic reports to your controller every time they are switched manually.
Is that something I can do from within Smartthings? Perhaps by with a Smart App or custom device type? I’ve hacked a few apps together, but I’ve never dealt with device types or parameter changes.
EDIT:
Okay so I messed around with a custom device type. I copied the “Configuration” code from the Aeon Multisensor, but changed the payload to deliver what I think is the correct Parameter change. When I apply that new device type to my Micro Switch, the Configure tile doesn’t show up in preferences. I must be missing something silly. Here’s the code so far:
metadata {
definition (name: "Z-Wave Switch with Perameter Change", namespace: "smartthings", author: "Smartthings") {
capability "Actuator"
capability "Indicator"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Configuration"
fingerprint inClusters: "0x25"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("indicator", "device.indicatorStatus", inactiveLabel: false, decoration: "flat") {
state "when off", action:"indicator.indicatorWhenOn", icon:"st.indicators.lit-when-off"
state "when on", action:"indicator.indicatorNever", icon:"st.indicators.lit-when-on"
state "never", action:"indicator.indicatorWhenOff", icon:"st.indicators.never-lit"
standardTile("reporting", "device.reporting", inactiveLabel: false, decoration: "flat") {
state "reporting", label:'', action:"reporting.reporting", icon:"st.secondary.configure"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main "switch"
details(["switch", "refresh", "indicator", "configure"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x70: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug "Was hailed: requesting state update"
} else {
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
def value = "when off"
if (cmd.configurationValue[0] == 1) {value = "when on"}
if (cmd.configurationValue[0] == 2) {value = "never"}
[name: "indicatorStatus", value: value, display: false]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
[name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue("manufacturer", cmd.manufacturerName)
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
def refresh() {
delayBetween([
def indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on", display: false)
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
def indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off", display: false)
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()
def indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never", display: false)
zwave.configurationV1.configurationSet(configurationValue: [2], parameterNumber: 3, size: 1).format()
def invertSwitch(invert=true) {
if (invert) {
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
else {
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
def configure() {
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 80, size: 1).format()
Any ideas would be greatly appreciated.
