Schlage Touchpad Deadbolt Setup Instructions
Hi Smart Things! I just wanted to make you aware of a slight tweak needed in your set up messaging for the Schlage Connect Camelot Touchscreen Deadbolt with Built-In Alarm, in this FAQ link:
This post says:
While the Hub is searching, bring the lock within 10 feet of the Hub, then:
Press the Schlage button on the lock
Enter your 6-digit programming code
Press 0
You do not press the Schlage button after you enter the 6 digit code. You simply press 0 after inputting the code and you are good to go. Just thought it might help someone else save a couple minutes of headache.
This is helpful. It was very hard to get the Schlage connected. Are Their range issues with the slage, camelot?
