Natec
April 10, 2017, 3:04am
1
The Satin Nickel finish is on sale at Amazon (most other colors still $189-220) currently. Camelcamelcamel shows that this price is as low as it has been since it briefly dropped to $130 last May.
Some tricks for pairing were discussed in this thread:
The initial pairing needs to be close to the hub so that the lock can exchange an encryption key with the hub. This is sometimes called “whisper distance.” Typically it’s within a couple of feet. But it doesn’t matter whether you bring the lock to the hub or the hub to the lock, they just need to be close together at the time of the initial pairing so the key can be exchanged.
There is an additional issue which the OP in this thread was fortunate enough not to run into, but which a number of other community members have, which is that the schlage model performs a bolt calibration at the time of pairing. For this reason, if you don’t have it installed in its intended location at the time that you do the pairing, this calibration may be off, causing the lock to jam after you move it. …
