RBoy
16
What other features are you looking for? If you want to use the full extent of the features of the lock you may want to consider using a customer device handler that can use all the features like:
And then a SmartApp to program the user codes like:
These apps require you to get access to the RBoy Apps server, but look at threads and you’ll get an idea of what all you can do with a lock like the BE469.
Like Tyler had mentioned earlier, physically the locks are identical, they are just branded differently for Wink or Iris or Nexia etc. It’s possible you may have received a “returned” item since you said that you had to exclude it first to use it.
