Samsung smarthings
Hi I have hyuawei p30 pro had this smarthings app for the last 3 years working no problem as now she disappeared from my phone and cannot install back from Google play says this app is not longer avaible for my phone don’t know why Samsung does this things for existing customers I was using this app for Samsung TV any one have solution how to install it?
Installing an APK compatible with your Android version is not without risk and there’s no guarantee it will work. https://www.apkmirror.com/apk/samsung-electronics-co-ltd/samsung-smartthings-samsung-connect/samsung-smartthings-samsung-connect-1-8-14-26-release/#downloads
Thanks this works for my.
Hi,
I have some troubles connecting my Samsung Air Conditioner to Smartthings:
The installation of the app from the Android Play Store and the connection of the Air Conditioner to my samsung-account and to my Smartthings-App runs smoothly up to the final step. At the end, a plug-in should be installed that allows configuration of the individual air conditioning units. However, the installation of this plug-in does not work (it shows a loading icon for over 30 minutes, but no error message appears).
The app has been properly uninstalled, and the phone was restarted before reinstalling (several times). The app has all required permissions. The indoor unit can be added in the app and can be turned on and off, but no settings can be adjusted.
Thanks for your efforts!
Paul
