Unfortunately I could not figure out any way to downgrade the firmware. I saw some hacks in YouTube to get root access to the camera but it does not work with the latest firmware.
I am also desperately looking for a solution to roll back the firmware but could not figure it out yet.
Did you ever figure out the url path for the audio for these cameras? I am using the rtsp with blue iris but haven’t figured out the correct url for voice.
I am trying this on older outdoor camera… versoin 1.00_140901
I can communicate but do not get a header in the return result… I added extra logging there is no map.header
This inability to use the SmartCam without internet is probably the worst idea they could think of, if they want to assure security should as well allow their own application to access the SmartCam without internet via local network, but anyway this is the way Samsung “thinks”, or not.
Hi all,
Any of you have succesfully FIX the firmware update LOCAL-ip limitation?
I think it’s not FAIR from SAMSUNG remove this feature hiding it on firmware update.
I’ve spent 500 euro buyin 5 SMART CAMS 300 in synology and now simply i can’t no more use it.
What samsung suppose I have to do with it? and why in the firmware update the didn’t mention that updating the firmware will result loosing the local access to the camera?
My Costco SN-V6413B has been asking me to do a firmware update in the last few days. Has anyone been brave enough to try it to see if local access is still available?
It asks me every time I access the camera via the SmartCam app, so it’s just a matter of time before I absentmindedly say “Now” instead of “Later” .
Has anyone gotten this to work on a V2 hub? Am I better off upgrading the firmware and using the Samsung ST V2 integration with the P6410? Am I correct in assuming that Samsung’s integration will allow a 3 minute video clip to be taken when an intrusion happens and also one can view a live stream on demand? Is that better than Grzegorz’s DTH?
my SNH-V6414BN (smartcam HD Pro) unfortunately updated !
so I`m stick with limitation !!
I discovered this port
HTTP [80]
HTTPS [443]
Rtsp [554] /onvif/profile2/media.smp
943
Rtsp [4520] /onvif/profile2/media.smp
19531
40000
49152 /rootDesc.xml
if have 2 cameras SNH-E6440 BN
One with Firmware 1.00
One with Firmware 1.07
Is is possible to get out the Firmware (1.00) from one camera and then update the second one with that firmware?
(i want to do an downgrade, which is officially not possible)
Does anybody know the servers/urls the camera is looking for new firmware? maybe it is possible to use a own dns server and then redirect it to an own server wich serves the firmware…
Just wanted to reply back to this old thread and say thanks. I don’t have a SmartCam, I have a WansView NCM625GA, but as I was trying to get it to work I found that it was Digest authentication also. Used your code (slightly modified) and was able to get it to work. Thanks!
By the way, in case anyone else uses this code above: I had to edit the getPictureName method. It was including the device ID in the filename, which means it was including the colon between the ip and port. That was causing the image to not show in the app for me.
I also removed the whole “Taking” tile state because it gets stuck whenever it requires a second authentication.
I have contacted the Federal Trade Commission (FTC) and filed an official complaint against Samsung Corporation and Hanwha Techwin (the developer of the camera/firmware) regarding this matter. The reason I did this is that the behavior of the manufacturer and/or it’s contracted developer(s) is reprehensible–the company only initiated a firmware update to remove third-party access/development/support after they realized there was revenue to be made through their own service; what’s worse, in the firmware update and the TOS/TOU, the consumer was never informed that A) this was possible, and B) this behavior had been included in the new firmware. The nail in the coffin was the fact that the company also did not A) provide an informed opt-in/out function with the firmware, nor did they B) provide an option to downgrade the firmware (to date). I encourage others to do so as well because after hours of deliberations with multiple representatives across three (3) companies/subsidiaries regarding this firmware issue and the anti-competitive nature of it, the only recourse is first FTC initiated action, and then a class-action lawsuit if the company does not comply. If the FTC cannot take action, I will be submitting this for CAL at earliest, because if it has happened to me (us) it has happened to millions of others undoubtedly across the IP camera marketplace. The URL to file a complaint in the United States of America is here: https://www.ftccomplaintassistant.gov
