Hello Community. I am not receiving Text Notifications on my IOS device from SmartThings
- Located in the US - Opted in for Text Notifications
- IOS 14.4, Created Automation to show when the door opened in Samsung Smarthings App
- Added US phone number for the “THEN” Statement (shows the number added with a red circle with a white line through middle) but “SAVE” button is grayed out.
Can’t find any solutions that work in the community. Looking for potential solutions
Contact Open/Close sounds easy enough, I assume for (3) you are stating that the number has been successfully added, and its not the problem, the problem is automation not running.
- Have you ever had SMS notification working? Or this is the first time. How long ago did you perform (1)?
- I’m asking the obvious, but on the Automation List page, the Enable toggle (grey=disable, blue=enabled) is in fact Enabled right?
Like a No Entry road sign? That doesn’t sound good.
I can’t tell if you don’t receive texts or can’t set them up to start with.
Yes. Exactly, like a No Entry Sign.
If shows the number added, but you can’t press the “SAVE” in the upper right corner, so maybe it is not setting it up properly. I am not receiving any texts.
A phone number is added by:
- Enter the number
- Press the (+) to its right
- A Number Bubble appears below with a red/white (-) to its right
- Click ‘Save’ at the upper right corner of the screen
If you then go back to SMS notification screen again. You will see:
5. A Number Bubble with a red/white (-) to its right
6. The ‘Save’ option on the upper right corner is grayed out, not clickable.
When you say ‘Save’ option is not available, do you mean step 4 or 6?
Were u able to get any resolution to this? My texts are not coming through either. Same “ no entry” sign.
