Samsung Q990 Soundbar Input Switching Workaround for Alexa
Issue:
Samsung HW-Q990 soundbar will not switch inputs using Alexa voice commands.
Root Cause:
Samsung appears to have changed their SmartThings/Alexa integration, now requiring API keys or limiting certain commands (like input switching). As a result, Alexa cannot directly change inputs through the usual smart home routines.
Workaround Overview:
To bypass this limitation, I used an IR hub and programmed it to mimic the original Samsung remote’s input behavior. Hubs like Logitech Harmony, BroadLink, or SwitchBot Hub Mini can do this. I used SwitchBot in my setup.
The challenge with Samsung soundbars:
Samsung doesn’t provide dedicated IR codes for each input (e.g., HDMI1, Optical, Bluetooth). Instead, there’s a single Input button that cycles through the options. This creates a problem: the current input state isn’t reset when the device powers off, so sending a fixed number of “Input” presses becomes unreliable.
Solution: Using the Bluetooth Pairing Button as a Reset Point
I discovered that pressing the Bluetooth pairing button always resets the input state to a known position. With that behavior, I was able to build reliable routines using a fixed sequence of button presses.
Steps (Using SwitchBot Hub Mini):
  1. Create a new virtual remote in the SwitchBot app:
  • Use a predefined template, not a custom remote (custom buttons don’t integrate with Alexa).
  • Map your Samsung soundbar’s remote buttons to the template. For example:
    • Assign the Bluetooth Pairing IR signal to the Power On button.
    • Assign the Input Cycle IR signal to the Power Off button.
  1. Create a Scene for each Input:
Example 1:
Scene for Digital Input
  • Step 1: Press “Power On” twice (this sends the Bluetooth pairing command twice).
    • First press wakes the soundbar.
    • Second press puts it in Bluetooth Pairing mode (our reset point).
  • Step 2: Press “Power Off” once (sends one Input Cycle press).
    • Now it’s on Digital input.
  1. Example 2:
    Scene for HDMI 1
  • Step 1: Power On (Bluetooth Pairing) x2
  • Step 2: Power Off (Input Cycle) x2
    • Result: input now at HDMI 1
  1. Example 3:
    Scene for HDMI 2
  • Power On x2
  • Power Off x3
  1. Example 4:
    Scene for Bluetooth
  • Power On x2
  • Power Off x4
  1. Integrate with Alexa:
  • Link the SwitchBot Alexa skill.
  • Create Alexa routines that trigger each scene by name.
  • Now you can say:
    • “Alexa, set soundbar to Digital”
    • “Alexa, set soundbar to HDMI 1”
    • “Alexa, set soundbar to Bluetooth”
    • etc.
Optional: Map Additional Remote Functions
You can also use the same technique to map other frequently used functions from the original Samsung remote, such as:
  • Sound Mode
  • Volume
  • Mute
  • Woofer Level
Just assign those IR signals to other unused buttons in the SwitchBot template. Then, you can create scenes or routines for voice control of those functions as well — e.g., “Alexa, set sound mode to surround.”
Why This Works Well:
  • The Bluetooth Pairing button gives a known starting point, which solves the unreliable cycling issue.
  • The scenes are stable and repeatable.
  • You can now build complex Alexa routines — for example:
    “Alexa, turn on Media Center PC” → powers TV, sets correct soundbar input, and wakes the PC.
Final Thoughts:
This isn’t the cleanest solution, but for a workaround, it’s functional and reliable. You get dependable input switching and can extend it to other soundbar features as well. I hope this helps others facing the same limitation with Samsung soundbars and Alexa
I just got a question for you which HW-Q990 Model year do you have B (2022), C (2023), D (2024), or F (2025). I ask as I have right now a model year B, C, and F. I’m having something similar with my model year C that has been sent in for repairs twice now and both times has been returned unfixed. Come to find out it’s a firmware issue that Samsung refuses to acknowledge. I also know model year Ds were getting bricked from a firmware update that was done OTA that had similar problems and at least Samsung is seeming to acknowledge that issue. As for the model year Bs and Fs they seem to not have any issue.
@MPHDodgeDaytona
Hi there — I have Model B. I contacted both Samsung Support and SmartThings Support a few months ago. Initially, they each tried to shift the blame to the other, saying it wasn’t their responsibility.
Eventually, Samsung admitted it was a known issue and said they would escalate it to engineering to be addressed.
That said, I personally believe they were fully aware of the problem from the start and have no real intention of fixing it.
Thanks, and best of luck
I got the Q990F a week ago. The sound is great, but the Smartthings integration, which is a big selling point is anything but smart. Anything reasonable u’d like to do u can’t:
Change to night mode at night?! No!
Change the Sound Mode based on the App/Channel? No!
Change the volume of the Subwoofer based on the time of day? No!
All you can do is turn the bar on/off and set the volume, which is easily done with almost any TV remote, anyway…
And it’s not that the soundbars doesn’t have the capabilities for all of the above and more… It’s just that Samsung doesn’t feel like exposing them for automation. AFAIK the only thing needed is sorting out the Device/Capability Presentation, since all the required functionality is already there.
Don’t get me started on the fact that the Soundbar does even have the option for local control, but there’s 0 information from Samsung on how to do that.
