I have a Samsung Premium Aircon with WIFI. It used to work with Alexa via Samsung Smart Home App. With Smartthings, it is not discovered anymore in Alexa. Also, I tried creating scenes which I deleted already but Alexa still discovers them.
Hi there - I just found your thread, I seem to be having the same issue, installed a Samsung AC, have it working OK in SmartThings (that wasn’t documented very well!). But Alexa will not discover it. I’ve tried looking at the setup in the Web portal - I’ve changed the type to a Samsung OCF Air Con (as this wasn’t set), I’ve tidied up names etc. I’ve also tried creating a dummy AC unit - neither are found when discovering devices.
Did you get this working at all? I’m running out of ideas, I’ve only used SmartThings for this and not Samsung Home App.
Unfortunately never worked. Even with the latest updates. What I did is use my broadlink smart hub and connected my samsung Aircon to it so that my Amazon Echo will recognize. Not perfect but works.
Hi - was this a smartthings update? I’m in the U.K. and haven’t had an update for two weeks. How did you find out it now works, in the alexa app? Finally which device handler are you using. I’m really hoping this is on its way here shortly.
I got a Smartthings App update last Oct 22. Did you activate the smartthings skill on The Amazon Alexa App? The Samsung Aircon just became recognized on the Alexa App.
I’ve been able to add my AC System to SmartThings. It wasn’t easy. My First Wifi kit came with a problem, so Samsung came along and replaced the board. It worked. After 3 hours we managed to add it to smartthings. Yes… 3 hours…
Ow, about the wifi kit, it only works with 2.4Ghz, do not expect it to work well with your wi-fi 6 router… it constantly gets offline… I will need to buy some old router just to make it more stable…
Now, when I try to create a routine to turn it on, It shows only one switch. Air Conditioner on/off. I have 5 rooms here, and I can turn them all on or off, but not a single room.
Somehow the rooms are inside the Air Conditioner device. From SmartThings perspective, it is a single device. SmartThings can not detect the rooms inside it.
I’m worried that this will be a problem when a manage to sync it with Alexa, but right now, Alexa does not find the AC System. I’ve been trying for days and haven’t found a way to make it happen.
I tough it will be easier… and I just choose Samsung because of SmartThings, believing it will work like a charm… so naive…
My system is a mini vrf. Maybe with a multi-split things works better…
This thread is going to make his 3 birthday and people still have problems with this.
