It was only a matter of time before ST made “Rules”, a terrific application with so much functionality, roll over and play dead with the loss of state and stored variables or whatever causes them to go “headless”. You cannot program around a dynamically corrupt platform or database.
Randomly, and without notice, my defined rules have become ineffective over these past few months (ST related platform performance degradation). It is annoying if not maddening and I am starting to trim back some of my more critical needs until ST can hold state variable.
Today was a very disappointing day for me. As I have cleaned up my decapitated rules, I have created instances of Smart Lighting to compensate for the lost Rules. After creating two Smart Lighting instances (one for true one for false) for each rule, I checked my local apps and no longer have any. I’ve heard rumors that once a Smart Lighting instance is disqualified to run local all other disqualified too, but I didn’t believe it. Now I do.
bamarayne
4180
Are you saying that if you have a single smart lighting instance that is not running local that none of your smart lighting instances will run local?
There’s no way. I have around 24 smart lighting rules, and 19 of them are running local right now. I just checked.
The only thing that has changed is that I added a few new instances with Hue lights. And the Hue are the only cloud devices, everything else is eligible to run local.
bamarayne
4182
I’ll add one with a hub bulb and see what happens. hold on.
Edit:
I don’t know man, I just made a quick rule in smart lighting using a local running contact sensor and a hue bulb. Nothing changed on my list.
bamarayne
4184
Huh? oh, wait… I think I know what you mean… I made rules in smart lighting that I knew were going to run local and they didn’t show up until I went in and clicked done on them.
In light of the ongoing serious degradation of the SmartThings platform, and the total lack of transparency into the problems with the platform by the company, I have reached the conclusion that it is prudent to no longer support Rule Machine in this environment.
Rule Machine is subject to random failure due to the degraded platform. The platform randomly causes corrupted Rules that may continue to function in unpredictable ways. There is nothing that I as the author can do to correct this. I cannot in good conscience recommend that you rely on Rule Machine. SmartThings itself offers no support.
You may continue to use Rule Machine if you have installed it. There will be no support other than that provided by other Community members. USE AT YOUR OWN RISK. You may not distribute Rule Machine or Rule to others.
So sorry to hear about your decision. It doesn’t come as a surprise. I hope that one day Rule 10.0 will come back! If you find a new home for it, or a better home for your ideas, please, please let me know.
I can understand where your coming from but NOOOOOOOOOOOOOOOOOOOOOOO. Rule Machine has made Smart Things livable. I hope that ST can find a way to make you keep developing. I’m sure your not the only developer who is frustrated and without you developers the system is pretty much useless.
Hopefully you will come back in the future if not and you use another platform let me know
bamarayne
4192
That is extremely upsetting but not in the least bit unexpected.
I sincerely hope that you remain in the forums and if, IF, smartthings gets their act together that you will begin support again.
I honestly believe they will, but I understand that you have a much deeper vesting in their platform than I do, and I do not blame you for this move.
Unfortunately, I also believe this is only the beginning.
As others have said, please let me know if and when you find another platform, as I would definitely join you.
I totally understand the decision. I would do the same (Beeing a server admin on a shitty hardware
Waisting time in debuging when it’s all related to hardware).
Fully understand and respect your decision - and please let me once again thank you for all your contributions that furthered ST even against all odds!
I do have a small question though - does the ST IDE currently display another “feature” where all my apps and device handlers show up in blue, listed as vcs.source.null on mouse-over or is this caused by my account still being linked to the Rule-Trigger Github repository that is no longer available? Anyone else seeing this? I was not able to figure out how to remove the repo to check whether this would solve the issue - I remember there being a delete button somewhere but have not been able to find that today…
