Actually, I think what @Michael_D has is correct. The rule will be triggered by one of them leaving. Once it is triggered, the condition is checked, and it will correctly see that that person is not present. That is exactly how I would recommend setting it up.
If you try it and it doesn’t work, please let me know.
SmartRules is able to provide a nicer, easier interface, since we are not limited to the few available interactions available for SmartApps.
SmartRules can also provide some functionality due to the fact that it is a native app, that the others will never be able to do. For example, SmartRules has QuickTap triggers, which creates buttons for quickly triggering a rule in your Today screen or on your Watch.
Also, its only $7, not $9 as JD mentioned in his post.
Looking to try this out, so I downloaded the Lite version. When I ran the App, it told me no client was available. So, after much checking, I found out that I had to load a SmartRules SmartApp. I have looked through all the Apps in the Marketplace, and cannot find it. I don’t even have a section marked Convenience. Help, please…
Hi Andy. There is no need to manually load the SmartApp. Please let me know where in the documentation did it make you think that so that I can fix it.
Now, about the actual problem… Are you in the UK/Ireland? If so, you’ll need to wait for an update coming very soon. If you’re in North America, then this is very strange. Please send me an email to brice at obycode.com and I’ll help figure out what is going on.
I got it from the error I got when trying to run the SmartRules App, telling me there was no client, so I assumed I had to go get one. From what you say, this now appears to be a regional thing. Perhaps some notes on your web page making this clear would help others. I know it would have saved me a whole mess of trouble… And, yes, I am in the UK.
Sorry about that confusion. We removed the paid version from sale in the UK until this is resolved, but forgot about the free version. It is now removed.
Thanks Bruce … I bought it. First tried the free one and it worked but was too limited to really get a feel. I figured only $7 bucks was worth the risk given the other smart home investments I have made. Anyway I have it now and am trying it out. So far so good. I was expecting to find an “or” function but didn’t. I assume you implement “or” capability by just installing parallel rules? Or is there a simpler way? Rule Master uses ors and ands so I was expecting this.
Also, I didn’t see how to enable the quick triggers. Where would I find this? Is it just the big button on the main screen?
The triggers (“if this happens”/“if any of these happen”) are always ORed, because a trigger is an instantaneous event, so it doesn’t make sense to AND those. Then the conditions (“while this is true”/“while ALL of these things are true”) can be ANDed (default) or ORed. If you tap on the “ALL”, it changes to “ANY”, which ORs them together. There is not yet a way to do anything more complex such as (this AND this) OR that.
You create a QuickTap trigger by adding “QuickTap” as a trigger for the rule (all the way at the bottom of the list). Then you’ll need to enable SmartRules in your Today screen (swipe down from the top of the screen, slide down to Edit and add the SmartRules widget). Now you’ll see your rule icons in the SmartRules widget. Just tap one, and it will execute the rule.
How is time logic applied? I have rules that should only occur between two time intervals (Ex. After Sunrise AND before Sunset). However, rules contingent upon both of the time conditions don’t appear to function properly.
Also, any plans to introduce the ability to edit existing rule conditions? What about the ability to copy a rule to make minor conditional adjustments?
The times are checked for within the current day, so “After sunrise” AND “Before sunset” should work, but “Before sunrise” AND “After sunset” would never be true, you would instead need to use “Before sunrise” OR “After sunset”.
At some point, I think we’ll make a single condition for time being between two times so that it is more clear.
I just stumbled upon this discussion and the app. Just wondering if it can help set up a rule like the one below
"When my schlage lock is unlocked at Night (night mode), the foyer lights should turn on and then turn off after a minute"
I can seem to do the turning on when the door is unlocked, but not the turning off after a minute
I moved from Wink to Smartthings. While ST does much more, I haven’t been able to create this rule for door open/close or door lock/unlock. Wink did this well.
Yes, SmartRules has an optional delay on actions, so you can set a rule to trigger on the door unlocking, add a condition to check if Night mode is active, then add two actions to turn on the light (with no delay) and then turn off the light with a 1 minute delay.
No, you’re right. Its not there in the lite version. That version is severely lagging behind because its a pain to keep updating both.
Actually, when we release version 2.0, the Lite version will disappear and the full version will become freemium, where it is free and has the same features, but is limited to one rule, like the current lite version, and then has an in-app purchase for unlimited rules. This way, we don’t have to keep two separate versions in sync, but you still get to try it out for free .
Hi obycode! I’m having a challenge getting quicktaps to appear on my today screen. I can see the smartrules section on the screen, but it is dimmed out, and my quicktaps don’t appear. Can you suggest anything? (i have yet to locate any sort of comprehensive documentation for this app…)
thanks, jeff
Hi Jeff. That’s strange. The only Issue that I am aware of is that for some strange reason, if you have bold text enabled in your accessibility settings, the QuickTaps will not show. Is this happening to you? If not, please send a screenshot.
