I know you’re new so you may have a posting limit, but if you can show screenshots of your routines it would help a lot.
Also, you can do everything you want to with one automation if you use core. It’s sort of like a scripting language for SmartThings. Very powerful and particularly good for “if A then B unless C” kind of stacked conditionals. So you might want to just jump straight into that because you’ll end up with a much more elegant solution. Set up is more complex, but there are a lot of community members who will be glad to help you with it if needed.
