In the ST app, I’ve created Routines on the device through the “Device” tab. Tried on two different devices and both times the routines would not execute when conditions were met.
I then created the same Routines on the “Automations” tab and they work. They are visible on the device when I click the “Routines” tab on the device and they are visible on the “Automations” tab in the “Routines” section.
Am I doing something wrong? Are others seeing this same behavior?
Device 1 is an Ecolink door/window sensor with dry contacts. I’m using a Zoom 24 V relay on the dry contacts.
Device 2 is an Aeotec TriSensor motion sensor.
In both cases, I deleted the routines from the devices when I couldn’t get them to work and then re-created them in the Automations section. Screenshots of the new Routines in the Automation tab are attached.
