I just got a email that they released Control-R 2.0 and that i need to update my app and the firmware on my controller. I really hope this fixes the integration… unfortunately when i attempt to do a firmware upgrade it fails.
Has anyone successful performed the upgrade and can confirm it’s working. I really hope this is it after 1.5yrs of badgering both Rinnai and Smartthings…
I know there are a number of different accessories that can be added to different rinnai models With different temperature controls and recirculation options.
I just wanted to mention that if you get one that has physical buttons, you can probably use a SwitchBot, which is a tiny actuator, essentially a robot finger, to physically press the button. These have an official SmartThings integration and work pretty well. I use them in my own home. they are battery operated and do not require any wiring and don’t void any existing warranties.
the button pusher itself is Bluetooth and connect to its own mini hub, so you might have to locate the mini hub near the device with the buttons. But then the mini hub uses Wi-Fi to access the Internet so as long as you have a good Internet signal, that part’s OK.
you have to buy one button pusher for each button as well as the mini hub. These are often on sale for around $30 each. Which means you might end up with a total cost of 100 or even $150 depending on how much you want to automate.
So I’m not saying this is a good solution, but it may be a solution. People often use a SwitchBot for a heat pump, an air conditioner, A coffee machine, in my case a blender: anything where you just need to push a button. Once you have that, you can add it into smartthings automations as desired.
Available in the US, UK, Japan, and some other countries.
Again, I’m not saying this is a good solution, or to let up on pressing the company for better integration, but it might work for some people given the investment that’s already been made.
Here’s a review I wrote on the SwitchBot for this forum:
Same here. Tried from both iOS and Android, before and after updating the Control-R app. So disappointing. There appears to be a Control-R 2.0 app in the app store that you’re supposed to use if and when the firmware update completes.
I’ve been wanting real smartthings integration for 2 years now. I’ve been on the phone multiple times with them about it but they’re never any help. I got the email yesterday to update the firmware and update the app. Honestly I’m afraid to do that because knowing the history of the module firmware and app I’m sure updating will be a nightmare and so will the new app. hopefully somehow they figured out how to get Samsung SmartThings integrated with the module.
I really wish I would have bought a different water heater. The whole integration has been a complete failure!
I have a support ticket in with the girl i been dealing with to see if she can push someting down to my module. I’m dead in the water right now.
I’m actually on hold with Rinnai right now (40mins wait so far and no answer).
Reading the comments in ControlR-2.0 App in the Android App Store sounds like everyone is having the same issue, wont firmware update - a complete flop.
My app is all greyed out and shows the unit offline now with only the option to update the firmware - which doesn’t work. Looks like it’s pooched.
Thanks for all the info! I’m going to hold off as long as possible updating the firmware and the app. Unfortunately with the track record they have a firmware update is only going to make it worse. I was afraid of this when I got the email. I figured it would be a complete flop.
Mine is bricked too. Factory reset doesn’t work. After 45 seconds, the led flashes red and white and then eventually returns to blue. I can’t get the unit back into pairing mode, and I’ve already removed from the app. I think I’m hosed.
Waited a little over an hour with customer support and finally got through. They’re slammed because of this issue, hence the wait. They said that they’re manually going through the list of affected customers and somehow fixing the issue remotely. Apparently I’m #3 on the list, and she says it will be fixed today. The firmware update will be applied after they fix it. Fingers crossed. Will report back on whether or not the update resolves the SmartThings integration.
My support contact pushed the firmware down to my module. Just attempting to reconfigure the Control-R though the new app and it asks to do a software update to the module… which just sits spinning.
They choose the wrong time to do a poor release of software lol
Never heard back from support (maybe because of the holidays), but my hot water heater finally showed up in the new Control-R app. I am not prompted to update the firmware, and I can control the hot water heater from the new app. I agree that the UI looks more polished, but I would argue that it’s less intuitive.
Anyways, the user account created in the new app is different from the user account in the old app (new password, etc). As best I can tell, both SmartThings and Alexa still rely on the old account/credentials…so I cannot link Rinnai to either one.
If you have not updated your firmware in the old app, don’t. Huge pain in the arse with reduced functionality. If I ever get it working, I’ll post again. Curious if any others have been able to relink with Alexa/SmartThings after the firmware upgrade though.
I’m still using the old app and old firmware. Does the new app and firmware give you the technical info the old app does like GPM, inlet temp, outlet temp, etc?
I was able to login to the 2.0 app with the same credentials as the 1.0 app. It shows a water heater associated with the account but says it’s offline. Not sure why or if I should create a new account. Also worried about trying to delete and re-pair the control-r unit with the new app and losing my Alexa integration.
My support contact had to push some changes down to my module 2x and then i got access to my unit.
Over the holidays some things were broken eg. Set temperature dial
They did recently update the Android App for Control-R and its now fixed. She did say Smartthing / Google Home integration wasnt 100% in the new system yet but i checked last night and i can link my rinnai account to smartthings now.
So far it’s kinda crappy the integration. Our rinnai heaters change temperature in increments of 5deg and the makes me do 1F at a time. Also it appears to not update the status of the heater as push, i have to manually update the smartthings window for it to see any changes… lets hope it gets better.
Woohoo! Finally some good news! I’m also able to connect to my water heater both from the new Control-R app and SmartThings! And, for the first time, my HomeBridge SmartThings plugin is working, so I can have HomeKit triggers (i.e. motion in the kitchen) start recirculation. Fingers crossed that the ST auth token doesn’t expire this time!
Alexa linking still appears to be broken, but I don’t really need that anymore as long as HomeKit/SmartThings automations continue to work.
