So I have an EverSpring ST812 flood sensor that set off a false alarm last night. Putting aside the fact that the siren I have set up through the home monitoring of ST did not trigger, I continue to get push messages from ST v2 that the basement is wet. Is there a way to reset the sensor from the hub, or do I need to reset the sensor itself?
You probably need to dismiss the incident in Smart Home Monitor.
GREAT!. I should have looked there of course. Now I can at least get some work done before going to reset the sensor. I’ll be back to figure out why the siren didn’t sound.
