Req: notify if light left on for more than x seconds
Hello,
It seems that using built in smart lighting and shm I can setup notification for doors left open; but I do not know how to setup notification for lights left on.
Anyone know how to do this?
Thanks in advance
Not sure what kind of “lights” you are using (probably sockets ? ))… there is a generic ST App - Energy management for POWER meter if you are using those? Quick easy if you are.
Not energy meter sockets.
Regular zwave wired light switches, like a GE zwave light switch.
Example, if a light was left on for 2 hours, send notification.
I have this setup for the garage door, left open for more than 1/2 hour, send notification.
That is a great idea. I have 2 switches that get left on all of the time.
If you use CoRE you can write a piston that will do anything you want if Light “X” stays on for a specified length of time - send a notification, automatically turn it off, whatever. I have a hallway light that turns on automatically with a motion sensor and then turns off automatically after 10 minutes. Similarly, a closet light that turns on automatically when the door opens and off automatically after 5 minutes even if the door hasn’t closed.
Can someone help with an example with core?
I am looking at a then action and see control actions, but I am not seeing notification options
I think you need to enable advanced options for that.
CORE has its own peer assistance thread. If you ask there, I’m sure someone will help you. :sunglasses:
