Hello,
I am looking for some help on setting up a notification if a certain light is on for more than 1 hour. I thought I had this working at some point in Core, but when I moved over to webCore it seems to have stopped working.
Basically I’m using the “was” operator but that appears to be wrong. Something similar to:
if “light” was on for > 60 minutes then send push notification
However, that is only sending the notification after the light is actually turned off even if the light is turned off 2 days later. So that doesn’t help me know if if a light is on and shouldn’t be.
If I try to use the “is” operator, then I don’t get the option to set the length of time I want to measure.
Hopefully this is clear as I can’t get into webCore on the computer I’m on currently. Any help would be appreciated.
