Has anyone made a customized button controller that allows the app to be renamed. This is getting a little ridiculous trying to find the one I want to edit.
I’m using Smart Lightning with my button controller, and I can edit the name ST comes up with. What SmartApp are you using?
Use “Button Controller +” instead, it allows you to name each instance. Basically it’s the same as Button Controller with some extra features. It’s here: https://github.com/bravenel/SmartThings/blob/master/Button%20Controller%2B
Or, you can use Rule Machine to do these functions, plus many more, for buttons.
It’s called Button Controller. Like it shows in the screen shot.
I’ll try +. Thanks.
Sigh. 20 characters.
Custom, or is it in the Marketplace (if so, where)?
It’s in the marketplace, under “More”. First one. “Button Controller”.
Button Controller + works great. I’ll convert to Smart Lighting when (if?) I get the Hub v2.
If I use Smart Lighting do I have to make a new instance for every button? And will it work with the long press on the minimote?
I use button controller because I can program all 8 buttons in the single app… just sucks we can’t rename it.
I didn’t realize Smart Lighting would do that. Thanks, I have been using Button Controller, I will change, like the local processing.
