So, I switched to the SmartThings (connect) or whatever it’s called quite some time ago.
Well, I am repurposing a Z-Wave device (outlet) which I had routines set up for in the prior app.
But now, I can’t remove those routines because they simply do not exist.
Any suggestions on how to remove previously defined routines?
Agreed. If the IDE was a no go I think the only other alternative would be to load up the classic app and delete all the routines that are left.
I have quite a few routines and know that I will have to change them eventually. I’m still using the classic app because of my wink zigbee ceiling fan controllers and I currently enable SHM with presence.
I did end up installing it, just now. That worked. I had more routines that I didn’t realize. I’m going to convert them over to webCore in the next few weeks I guess.
