I just wanted to be forthcoming with news about the upcoming release tomorrow.
I have spent the entire day working on updates to the automations app and in doing so I realized just how inconsistent the apps input variable names were. I figured it’s better to standardize them now rather than later.
So I’m sure you’re asking what does this have to-do with me
After the next update all of your automations will need to be removed and recreated. I know this is an inconvenience but it’s something that needs to happen before the app gets any larger.
####With that said here is what’s coming tomorrow.
Select Notification recipients for each automation individually
Refactored Mode and Contact logic.
Added Switch to remote sensors for evaluation of Rules.
Today I was notified my Nest protect’s haven’t logged an event in 24 hours. My thermostats didn’t have this issue though. When I opened the device, I noticed the same. I hit refresh and it worked. My guess is ST was having scheduling issues again?
Something I’ve noticed. Not sure if this is just because I’m using a UK version, but if I tap on Heat, it sets it to Auto(not technical supported here) and the sets the temperature to - 20 degrees
Same here. My thermostat had not checked in since last night. Hit the refresh button in the UI and it updated. I also noticed it with the weather. Oh well…
Hi tonesto7… So, I am just wondering what the purpose is for this setting? If I am away, shouldn’t it just act like the nest usually would and stay in either heat or cool? (there is probably some really good help information in the app on this, huh…)
PS… can’t see your picture above since it seems to link to slack.
Technically when you Nest goes away it is in the Auto State… The problem I see now if that I need to modify that function to only be used if the locations supports heat and cool
@tonesto7 When I setup and automation for presence sensors, after I select mu phones it loads to a blank screen and will not go back into that setting.
Ok, so I’m ready to take the plunge and install the Nest Manager 2.0. I’m currently using Nest Direct. What’s the best way to delete Nest Direct and it’s smart apps so that it doesn’t interfere with Nest Manager?
