[RELEASE] Zooz ZEN73 700 Toggle Switch
There’s a driver available for this device on Zooz’s Edge Driver Channel.
Most of the information below is for the old Groovy Handler which will stop working on 9/30/2022.
This is a DTH for the Zooz 700 Series Toggle On Off Switch (ZEN73)
Features:
  • Switch
  • Supported Button Actions: down, down_hold, down_2x, down_3x, down_4x, down_5x, up, up_hold, up_2x, up_3x, up_4x, up_5x
  • Supports all Configuration Parameters
  • Association Group 2 for controlling other switches_
WARNING:
If you add a device’s Device Network ID to this device’s Group 2 Association setting and then remove that device from SmartThings, you MUST come back and remove it from that setting. Failing to do that will substantially increase the number of z-wave messages being sent by this device and could affect the stability of your z-wave mesh.
There’s a driver available for the Zooz ZEN73 Toggle Switch on Zooz’s Edge Driver Channel.
