Hi JF & James,
JF - thanks for working on adding Alexa support to the device handler! I’ve been using Alexa Helper which works great…but it would be so nice to have this functionality through the thermostat device handler itself. I think it would make things a lot smoother. I have 3 of the Zigbee Stelpro and 1 of the Z-Wave Stelpro thermostats through-out the house. Your posts and support on the forums has been invaluable in setting the thermostats up.
I’m experiencing the same issue as James with my Zigbee Thermostats and the beta device handler. When I ask for the temperature Alexa says “I’m not sure what went wrong” and when I say “Set the bedroom/kitchen/bathroom to 72 degrees” Alexa responds “that command doesn’t work on…” I tried turn the bedroom heat on and that worked (but it could have worked because that’s the same command I use with Alexa helper).
I’d be happy to help out in any way I can since I have 3 of these. I can send you logs, etc. as you work on getting the device handler working with Alexa.
Thanks again,
Kenn
