I am running the latest bridge firmware 2.6. I have http calls successfully working from other devices without fail every time. These devices are using the http api to open and close the lock and does not reset the bridge. The nuki app over the bridge (BT disconnected) also works flawlessly.
Its only the Nuki Manager that seems to keep randomly connect and disconnect with the bridge. Is this related to the recent bridge firmware update on the 13/07/2020. As I have only seen this problem surface over the last couple of weeks.
RBoy
42
We havenât seen any issues here using just the Nuki Manager. I suspect the other app youâre using may be causing the issues with the bridge. Try turning the HTTP API off and using only Nuki Manager.
When I turned off http api I lost access to the lock as expected from other devices but also nuki manager. I had to enable http api again for nuki manager to start working but again this morning itâs gone back to the earlier error of âhidden bridge foundâŚâ
Can you please help? I am not using any other app apart from using nuki api commands to lock and unlock from another device only when manually activated ie I donât have any automation setup from that device.
Thanks in advance.
RBoy
45
Iâm not seeing any issues here with our test bridges. Since youâre saying that it works fine for a while and then stops, my guess is the other integration youâre using may be resetting your bridge settings or possibly the hardware is faulty. Nuki manager doesnât reset any settings on the bridge so itâs something external (possibly through the HTTP API) thatâs resetting your bridge tokens/discovery. You may also want to check your power supply for fluctuations in case thatâs affecting the stability.
Thanks RBoy. The other device is just sending an http api command to âlockâ or âunlockâ the lock when I manually push the button. I am not sure that would reset the token/bridge discovery. I never have problem locking or unlocking from my intercom (other device), works every time. Itâs just the nuki manager that has an issue.
I have also written to nuki regarding this problem.
I am in one of the big cities in Australia and we donât have power fluctuations where I am. I have many devices on my network running of mains power that run without any issues.
Nuki has confirmed the bridge to be working. The problem with the nuki manager Smart app is the responsibility of the app developer. The bridge works perfectly via the nuki app and http api. Can you please please a resolution to your smart app?
Below is part of the log from the smart app. It keeps losing the IP address of the bridge for some reason
4:47:04 PM: trace Getting list of devices for [[bridgeId:XXXXX, dateUpdated:2020-08-27T11:45:02Z, expiredToken:false, ip:0.0.0.0, port:8080, token:XXXXX]
4:47:04 PM: trace Getting list of bridges from Nuki servers
4:47:04 PM: trace Hostname api.nuki.io has IP Address XXXXXXXXX
4:47:04 PM: trace Request was successful, status=200, json=respData
Every ow and then I also get the warning message:
4:48:06 PM: warn Bridge auth failed! Did you press the button the Bridge and is the âHTTP APIâ option enabled in the Bridge settings?
For my is the same problem of user rybackisback⌠Is imposible to configure Nuki Manager⌠when pulse de buton of Nuki Brigde and the app detect my Nuki Smart Lock⌠failed to created the object into the smartthings app⌠i try with classic and the modern app⌠and is the same problem!!
RBoy
49
Theyâre completely different issues. He has a bridge that is sending bad information for the Nuki server after a few days of normal operation.
What youâre describing is an installation issue where the platform is unable to create the lock devices. Sounds like you forgot to add or publish the Nuki lock device handler in the IDE. Uninstall the app and follow the step by step instructions and donât forget to install the SmartApp AND the device handler AND publish them both.
If youâre still having an issue feel free to email our support desk.
I dont forget anything⌠i publish both and still the same errorâŚwhen detect de bridge with the IP and the nuki with hostname⌠then failed tu create the object Nuki Smart Lock into the appâŚ
RBoy
51
Nuki Manager - v01.01.00
(New) Update for new SmartThings app
(Fix) Stop requesting bridge auth (push button) once install is completed if it wasnât pushed
Nuki Lock Device Handler - v02.00.00
Update for new SmartThings app with custom UI controls
Option to select default SmartThings unlock action (unlock or unlatch)
Dumb Question: do we need a STH for this using the handler and Smartapp?
RBoy
57
Great question: yes you do. This is an zero configuration discovery and setup integration which requires a Nuki bridge and a SmartThings hub to discover the bridge. Be sure to have the Nuki bridge and SmartThings hub on the same network without any firewalls so they âdiscoverâ/âtalkâ to each other.
Greetings! and with the opener is there compatibility?
RBoy
59
Nuki Manager - v02.00.01
(Fix) Improve callback registration when bridge is busy and clear expired callbacks to improve response (NOTE: For the changes to take effect, after updating the code, you will need to open Nuki Manager in the SmartThings mobile app and click Done)
Having just installed a Nuki Smart Lock 3.0 Pro (with integrated WiFi and no bridge), while knowing it wasnât supposed to be supported, I was a little hopeful thatâd be discovered as Nuki states the bridge is integrated, but it wonât, even after setting the lock to pairing mode.
Nuki Web shows the API active and allows to setup OAuth2 redirect URL and provides the key, moreover you can create API tokens.
Is there any chance or plan to make the manager compatible with this lock? Can I maybe help test in any way?
