Bought and installed the Device Handler for my Z-TRM 3 and updated the Type to Heatit Electronic Thermostat. It seems to be working except in the Smart Things app it just shows âCheckingâ instead of the temperature. If clicking on the sensor, the temperature is shown. What is strange is when I used the Type = âZ-Wave Thermostatâ it worked as supposed.
in the past weeks, my Z-TRM2fx has been going offline a lot. (like every 2-5 days). I do see in the trace, that every now and then it reports this:
12:21:04: warn IGNORING SPURIOUS BASIC_REPORT from endpoint null: BasicReport(value: 255)
Not sure if this is relevant. Mine are about 1 year old, and if this is an confirmed error, I would say that according to norwegian law, this is a âreklamasjonâ. Hence, they need to fix it or give me a new one. Or?
I have today added 4 Z-TRM3 thermostats with success. I am often away from home and have created an automation which turn all devices off and turn all temperature-controlling devices to a lower set-point. When trying to add the Heatit thermostats to the automation under âthenâ, they wont appear in the list of control units. Is this a common problem?
RBoy
#86
Sometimes the platform is slow and times out and it wonât show all devices. Reloading a few times usually fixes the issue. Historically weekends the platform is slow and times out more often.
My trm2fx has started doing the same thing - itâll stay online for about 24 hrs and then seems to disconnect requiring a power cycle. Iâve tried moving my hub closer and z-wave repairs but it makes no difference - did you resolve your issue in the end?
No, sorry. I just need to reset them. It is quite annoying, as Heatit has discontinued this one (and are now selling the trm3 instead), so they do not careâŠ
Hi. I have added the DH to control my TRM3, but I have some issues. For instance, when I try to add any automation it says âNetwork errorâ, couldnât add automation. This does not happen for HeatIt Temp2, which works fine. Also, Iâm a bit confused why automation only shows 2 options, which both are named as âTemperatureâ.
And why is it showing battery status, when this is not controlled by batteries? There are also 2 set temperatures in the main window as well as something called âmainâ and âdimmerâ which seems to now have any connection.
RBoy
#90
Itâs an issue with the SmartThings mobile app. Itâs working fine here on one phone but behaving differently on another phone. For the TRM3 it should show you 4 temperature sensor options (one for the main and 3 for the external / internal sensors). Try a different mobile phone (android) and if youâre set Iâll having an issue youâll have to report it to SmartThings support to fix the mobile app.
impossible to include parameters in an automation or scene. Neither is it possible set new temp values onto the device using the app, but the other way around works
Several instances of temperatures and fans, and infact a dimmer (!) shows up on the main" tile
RBoy
#93
As described in the post right above yours itâs a bug with the lastest SmartThings mobile app which is affecting many custom devices. They are aware of it but arenât providing an ETA for the fix. You can downgrade to an older version of the SmartThings mobile app (itâs working fine on v1.75.65.43 Android and iOS v1.6.67-520) and report it to SmartThings support so they can expedite the fix.
Firmware versions TRM2fx (3.06 and 3.04 ) and TRM3 (4.00) do not support resetting energy consumption over z-wave. This feature has been added for future firmware updates which may support energy resets over z-wave.
The UI may not reflect the new changes due to platform caching. One way to force the cache to clear is to change the device handler to Z-Wave Device and then back to this device handler from the IDE, then sign out of the ST mobile app and sign back in. If nothing else works, you may need to exclude your device, delete the device handler and reinstall it.
some strange observations; I have 4 HeatIt Thermostats. The UI changed with one of them, but not for the 3 others. When I push the reset on the one, I get the error messge âA netowork or server error occured. Try again laterâ.
Hi, got the app to send the Reset command. But it does not work. The Heatit still reports the same energy consuption.
The eventlog shows 2 events:
2021-12-22 9:20:34.000 AM CET
44 minutter siden DEVICE resetEnergy ready HeatIt Z-TRM2fx reset energy is ready
2021-12-22 9:20:29.000 AM CET
44 minutter siden DEVICE resetEnergy resetting Resetting energy meter
RBoy
#98
The current firmware for TRM2fx (3.06) and TRM3 (4.00) do not support resetting the energy over z-wave. This feature has been added for future firmware updates if they provide that feature. For these firmwareâs the only way to reset the energy consumption is to exclude and re-pair or factory reset the thermostats.
I have finally been able to install my 4pcs Heatit Z-TRM2fx Thermostat that i have bought a while ago. It was easy to purchase and activate the DH from rboy, but when trying to pair the devices with my smartthings app, i face some challenges.
Going to Con on the device, and seaching for nearby devices in the app.
The app finds the device, and i choose secure connection and scan the QR code.
The device confirms include, but the device pops up as âZ-wave device multichannelâ with no useful parameteres to be changed (f.ex dimmer).
