Thanks for the quick reply, updating to 02.01.01 solved the problem I hadnât notice a new version was out, installed it only a few weeks ago
Hi, I have installed RBoy device handle 02.01.00 on my smartthings v3. Initially managed to communicate with all my eight TRM2fx , however after a while I have noted that status of some thermostats went offline. I have already tried factory reset, reconnect to the hub, etc. Every time that I re-start the hub a different set of thermostats present this issue so I dot believe its related to the distance between them and the hub. From the hub utilities I have already run Zwave repair and got some errors like:
- Network repair for device [07]: Could not delete old routes
- Network repair for device [06]: Could not assign new route
- Network repair for Z-TRM2fx [11]: Could not update neighbors
- Network repair for Z-TRM2fx [10]: Could not update neighbors
- Network repair for device [0E]: Could not update neighbors
- Network repair for Z-TRM2fx [0D]: Could not update neighbors
- Network repair for device [0B]: Could not update neighbors
Zwave errors are mesh or device errors, unrelated to the DTH. It means that your device isnât responding. The TRM2fx has a known firmware defect in some versions which causes the device to hang under heavy mesh traffic after a while as explained here.
Thatâs nice, I have updated FW with cable from HEATIT. Two of the thermostats that went offline have direct contact with the hub. The thermostats also fail whery ofthen.
More people with same problem?
I have the same issue here. I have just updated firmware in eight units (used OTA instead of cable), however the problem is still the same, some thermostats go offline after a while. I have noted that they come back online after you reset them or switch the power off/on. I have raised the question to heatit and am waiting for a reply.
Ok keep me updated on the response from Heatit.
I also see this (online after reset). And I have the issue on both the TRM2fx and TRM3.
Feedback received from Heatit âI donât know what is going on there but you could try asking RBOYapps, they are the ones that make our intergrations for smartthings.â
Hi there. This is a known issue with the Z-TRM2fx model and isnât related to SmartThings. HeatIt engineers have been able to replicate the issue and we have also been able to replicate the issue outside SmartThings. When there is a lot of traffic on the z-wave mesh, the device z-wave module sometimes hangs and needs to be power cycled to resume operation. The 3.6 firmware improves the stability however a permanent fix will require an updated firmware from HeatIt. Once the device z-wave module hangs it will also impact any other devices that are routing through it until itâs restarted. It also helps to reduce traffic on the network from other devices.
Reply received from Heatit today:
âThere arenât any updates planned as this product is EOL (End of Life) and is succeeded by the Z-TRM3.â
I find strange Heatit be allowed to use the label âz-waveâ on its productsâŠ
Heatit have to take the responsibility and find a way to fix this or they have to take the âWork with SmartThingsâ away from the home page.
RBoy how can you sell a device handler to a product you know have a failure?
There have to be possible for Heatit to make a new FW, I got a cable from Heatit and updated the FW but I still have the same problem.
Hi just sendt this e Mail to Heatit
Heatit is a Norwegian company so the text is in Norwegian.
Hei sendte dere originalt denne mailen:
Hei
Er elektriker og har kjĂžpt 10 stk TRM-3 FW 4.00 som jeg bruker i mitt eget hus opp mot SmartThings. Bruker RBoy sin DH opplever at termostaten ikke varmer om jeg setter setpunkt fra SmartThings. Opplever ogsĂ„ at jeg etter en stund mister kontakt med termostatene fra hubâen. Ser pĂ„ div forum at det er en feil i FW jeg har i termostatene. Hvordan fĂ„r jeg oppdatert termostatene til nyeste FW versjon og vil dette hjelpe slik at de to feilene jeg opplever forsvinner.
P.s. Dette er en nyinstallasjon alt i huset er Z-wave kun termostatene som slutter Ä kommunisere med hun etter en stund. Det at det ikke fungerer Ä sette setpunkt forstÄr jeg skal vÊre ordnet om jeg fÄr oppdatert termostat.
Har fÄtt hjelp, kabel og FW brukt mye tid pÄ dette nÄ. Settpunktet kan nÄ styres fra ST men feil 2. Offline thermostat skjer fremdeles fra tide til annen.
Dette er nÄ et kjent problem pÄ kryss av alle huber, RBoy kan bekrefte at dere kjenner til feilen hva skal jeg gjÞre for Ä fÄ produktet deres til Ä fungere som tiltenkt.
Dere bÞr ta bort « works with SmartThings «pÄ hjemmesiden frem til dere har en lÞsning pÄ problemet. Dette er jo feilinformasjon, termostatenen deres fungere Max 30 % sÄ lenge dere selger de mot div huber.
My 2 Heatit TRM-3 is not possible to change set point from the smarthings app. They appeare online, and no errors. I used the newest DH . Why did I pay for a DH thats not working?
UPDATE: SmartThings has fixed this UI issue and the setpoint controls should now be visible again
Itâs a SmartThings mobile app bug. They updated the heating setpoint controls UI plugin last weekend and due to a bug the UI controls disappeared for all heating thermostats. SmartThings engineers are aware of it and the setpoint controls should return automatically once they fix it. Itâs doesnât have any impact on SmartApps or Automations used to set the temperature.
Please keep us posted in case of any feedback from Heatit. Tks!
Hi I have noted that in the DH code there are a couple of lines checking if the FW version is 3.04, however the latest FW file from Heatit seems to be 3.06. Is that anything RBoy should look at ?
Apparently the stability issue has been sorted out in the last releases (v02.01.03/ Dev02.01.04) of device handler. I am running it for a few days and so far none of my eight Z-TRM2fx went offline.
I am still using the same firmware 3.06âŠ
Hi! Just got the Heatit-thermostat installed by an electrician. Paired the device with the SmartThings app, but the Thermostat got recognized as a dimmer in the app. Donât know why and how to fix this. So now I can control the thermostat by switch it on and off, but not adjust the temperature. Does anyone know why and how to fix this? When pairing, I used the âGeneric Z-wave deviceâ option in the app. Did not scan any qr-code or set any pin code.
Hi
Are you still online with the new DH?
Hi. Added my Heat It Z-TRM3 to my Smart Things hub, and configured it as Type = Z-Wave Thermostat. It seem to be working in my SmartThing app. Do I gain anything extra paying for the RBOY Device Handler?
