I have a few light fixtures that have a narrow “shade” (it’s glass) around them and won’t fit a standard A19 light bulb. The length of the socket + bulb isn’t the problem in this case, it’s how wide the bulb is.
Does anyone know of any smart/connected light bulbs that are narrower than A19? The socket on the fixture is GU24, but I have adapters to convert to E26. I don’t need colors (just white), just would like to control brightness and each bulb individually. I’ve been searching all over and haven’t had much luck!
Unfortunately, the single light switch controls three lights in the room and I’d like a bit more flexibility there.
I wonder if there is some kind of module that could be put inline to control the light bulb, even if it’s on/off only. Then I could use any kind of light bulb that would fit.
That looks like an option, except that it appears to be wider than the A19 even. But I’ll look around some more and see if there’s another option along this line of thinking. I appreciate the help!
I never quite understood the use of Bluetooth for light control. Seems counter-intuitive to the whole home automation thing. I guess if you’re only looking to control one or two lights with your phone…
I ended up removing the glass lamp shades for the time being and using the $15 GE Link bulbs. It’s for an above sink fixture in the bathroom, so eh… It’ll work for now. And wow… they are bright!
Thanks all for the help! If anyone runs across anything, I’d certainly be interesting in hearing about it…
