Huh…I thought I had it working again, but it looks like it’s not even snagging any device info after auth’ing:
Prometheus metrics
# HELP go_gc_duration_seconds A summary of the pause duration of garbage collection cycles.
# TYPE go_gc_duration_seconds summary
go_gc_duration_seconds{quantile="0"} 4.0541e-05
go_gc_duration_seconds{quantile="0.25"} 7.3767e-05
go_gc_duration_seconds{quantile="0.5"} 0.000111843
go_gc_duration_seconds{quantile="0.75"} 0.000130754
go_gc_duration_seconds{quantile="1"} 0.0002245
go_gc_duration_seconds_sum 0.002753796
go_gc_duration_seconds_count 26
# HELP go_goroutines Number of goroutines that currently exist.
# TYPE go_goroutines gauge
go_goroutines 19
# HELP go_info Information about the Go environment.
# TYPE go_info gauge
go_info{version="go1.15"} 1
# HELP go_memstats_alloc_bytes Number of bytes allocated and still in use.
# TYPE go_memstats_alloc_bytes gauge
go_memstats_alloc_bytes 3.907912e+06
# HELP go_memstats_alloc_bytes_total Total number of bytes allocated, even if freed.
# TYPE go_memstats_alloc_bytes_total counter
go_memstats_alloc_bytes_total 3.7378296e+07
# HELP go_memstats_buck_hash_sys_bytes Number of bytes used by the profiling bucket hash table.
# TYPE go_memstats_buck_hash_sys_bytes gauge
go_memstats_buck_hash_sys_bytes 1.453775e+06
# HELP go_memstats_frees_total Total number of frees.
# TYPE go_memstats_frees_total counter
go_memstats_frees_total 315054
# HELP go_memstats_gc_cpu_fraction The fraction of this program's available CPU time used by the GC since the program started.
# TYPE go_memstats_gc_cpu_fraction gauge
go_memstats_gc_cpu_fraction 4.1536585891417105e-06
# HELP go_memstats_gc_sys_bytes Number of bytes used for garbage collection system metadata.
# TYPE go_memstats_gc_sys_bytes gauge
go_memstats_gc_sys_bytes 5.15996e+06
# HELP go_memstats_heap_alloc_bytes Number of heap bytes allocated and still in use.
# TYPE go_memstats_heap_alloc_bytes gauge
go_memstats_heap_alloc_bytes 3.907912e+06
# HELP go_memstats_heap_idle_bytes Number of heap bytes waiting to be used.
# TYPE go_memstats_heap_idle_bytes gauge
go_memstats_heap_idle_bytes 6.1169664e+07
# HELP go_memstats_heap_inuse_bytes Number of heap bytes that are in use.
# TYPE go_memstats_heap_inuse_bytes gauge
go_memstats_heap_inuse_bytes 5.44768e+06
# HELP go_memstats_heap_objects Number of allocated objects.
# TYPE go_memstats_heap_objects gauge
go_memstats_heap_objects 14485
# HELP go_memstats_heap_released_bytes Number of heap bytes released to OS.
# TYPE go_memstats_heap_released_bytes gauge
go_memstats_heap_released_bytes 6.0760064e+07
# HELP go_memstats_heap_sys_bytes Number of heap bytes obtained from system.
# TYPE go_memstats_heap_sys_bytes gauge
go_memstats_heap_sys_bytes 6.6617344e+07
# HELP go_memstats_last_gc_time_seconds Number of seconds since 1970 of last garbage collection.
# TYPE go_memstats_last_gc_time_seconds gauge
go_memstats_last_gc_time_seconds 1.6529721581640055e+09
# HELP go_memstats_lookups_total Total number of pointer lookups.
# TYPE go_memstats_lookups_total counter
go_memstats_lookups_total 0
# HELP go_memstats_mallocs_total Total number of mallocs.
# TYPE go_memstats_mallocs_total counter
go_memstats_mallocs_total 329539
# HELP go_memstats_mcache_inuse_bytes Number of bytes in use by mcache structures.
# TYPE go_memstats_mcache_inuse_bytes gauge
go_memstats_mcache_inuse_bytes 3472
# HELP go_memstats_mcache_sys_bytes Number of bytes used for mcache structures obtained from system.
# TYPE go_memstats_mcache_sys_bytes gauge
go_memstats_mcache_sys_bytes 16384
# HELP go_memstats_mspan_inuse_bytes Number of bytes in use by mspan structures.
# TYPE go_memstats_mspan_inuse_bytes gauge
go_memstats_mspan_inuse_bytes 70448
# HELP go_memstats_mspan_sys_bytes Number of bytes used for mspan structures obtained from system.
# TYPE go_memstats_mspan_sys_bytes gauge
go_memstats_mspan_sys_bytes 98304
# HELP go_memstats_next_gc_bytes Number of heap bytes when next garbage collection will take place.
# TYPE go_memstats_next_gc_bytes gauge
go_memstats_next_gc_bytes 5.922528e+06
# HELP go_memstats_other_sys_bytes Number of bytes used for other system allocations.
# TYPE go_memstats_other_sys_bytes gauge
go_memstats_other_sys_bytes 432409
# HELP go_memstats_stack_inuse_bytes Number of bytes in use by the stack allocator.
# TYPE go_memstats_stack_inuse_bytes gauge
go_memstats_stack_inuse_bytes 491520
# HELP go_memstats_stack_sys_bytes Number of bytes obtained from system for stack allocator.
# TYPE go_memstats_stack_sys_bytes gauge
go_memstats_stack_sys_bytes 491520
# HELP go_memstats_sys_bytes Number of bytes obtained from system.
# TYPE go_memstats_sys_bytes gauge
go_memstats_sys_bytes 7.4269696e+07
# HELP go_threads Number of OS threads created.
# TYPE go_threads gauge
go_threads 5
# HELP process_cpu_seconds_total Total user and system CPU time spent in seconds.
# TYPE process_cpu_seconds_total counter
process_cpu_seconds_total 0.52
# HELP process_max_fds Maximum number of open file descriptors.
# TYPE process_max_fds gauge
process_max_fds 65535
# HELP process_open_fds Number of open file descriptors.
# TYPE process_open_fds gauge
process_open_fds 13
# HELP process_resident_memory_bytes Resident memory size in bytes.
# TYPE process_resident_memory_bytes gauge
process_resident_memory_bytes 1.861632e+07
# HELP process_start_time_seconds Start time of the process since unix epoch in seconds.
# TYPE process_start_time_seconds gauge
process_start_time_seconds 1.65296937376e+09
# HELP process_virtual_memory_bytes Virtual memory size in bytes.
# TYPE process_virtual_memory_bytes gauge
process_virtual_memory_bytes 7.31549696e+08
# HELP process_virtual_memory_max_bytes Maximum amount of virtual memory available in bytes.
# TYPE process_virtual_memory_max_bytes gauge
process_virtual_memory_max_bytes -1
# HELP promhttp_metric_handler_requests_in_flight Current number of scrapes being served.
# TYPE promhttp_metric_handler_requests_in_flight gauge
promhttp_metric_handler_requests_in_flight 2
# HELP promhttp_metric_handler_requests_total Total number of scrapes by HTTP status code.
# TYPE promhttp_metric_handler_requests_total counter
promhttp_metric_handler_requests_total{code="200"} 200
promhttp_metric_handler_requests_total{code="500"} 0
promhttp_metric_handler_requests_total{code="503"} 0
# HELP smartthings_exporter_build_info A metric with a constant '1' value labeled by version, revision, branch, and goversion from which smartthings_exporter was built.
# TYPE smartthings_exporter_build_info gauge
smartthings_exporter_build_info{branch="",goversion="go1.15",revision="",version=""} 1
Kind of a bummer. Even w/ debug logging set, I can’t get any sort of additional info from the exporter to see what the problem is at this point
As far as I can tell, it’s auth’d and should be working:
Log info
May 19 13:46:09 metrics.sachshaus.net smartthings_exporter[2453857]: time="2022-05-19T13:46:09Z" level=info msg="Starting smartthings_exporter (version=, branch=, revision=)" source="smartthings_exporter.go:180"
May 19 13:46:09 metrics.sachshaus.net smartthings_exporter[2453857]: time="2022-05-19T13:46:09Z" level=info msg="Build context (go=go1.15, user=, date=)" source="smartthings_exporter.go:181"
May 19 13:46:11 metrics.sachshaus.net smartthings_exporter[2453857]: time="2022-05-19T13:46:11Z" level=info msg="Listening on :9499" source="smartthings_exporter.go:214"
May 19 14:06:17 metrics.sachshaus.net systemd[1]: Stopping The Smartthings Prometheus exporter service....
May 19 14:06:17 metrics.sachshaus.net systemd[1]: smartthings-exporter.service: Succeeded.
May 19 14:06:17 metrics.sachshaus.net systemd[1]: Stopped The Smartthings Prometheus exporter service..
May 19 14:06:17 metrics.sachshaus.net systemd[1]: Started The Smartthings Prometheus exporter service..
May 19 14:06:17 metrics.sachshaus.net smartthings_exporter[2456758]: time="2022-05-19T14:06:17Z" level=info msg="Starting smartthings_exporter (version=, branch=, revision=)" source="smartthings_exporter.go:180"
May 19 14:06:17 metrics.sachshaus.net smartthings_exporter[2456758]: time="2022-05-19T14:06:17Z" level=info msg="Build context (go=go1.15, user=, date=)" source="smartthings_exporter.go:181"
May 19 14:06:17 metrics.sachshaus.net smartthings_exporter[2456758]: time="2022-05-19T14:06:17Z" level=info msg="Listening on :9499" source="smartthings_exporter.go:214"
May 19 14:09:19 metrics.sachshaus.net systemd[1]: Stopping The Smartthings Prometheus exporter service....
May 19 14:09:19 metrics.sachshaus.net systemd[1]: smartthings-exporter.service: Succeeded.
May 19 14:09:19 metrics.sachshaus.net systemd[1]: Stopped The Smartthings Prometheus exporter service..
May 19 14:09:19 metrics.sachshaus.net systemd[1]: Started The Smartthings Prometheus exporter service..
May 19 14:09:19 metrics.sachshaus.net smartthings_exporter[2457152]: time="2022-05-19T14:09:19Z" level=info msg="Starting smartthings_exporter (version=, branch=, revision=)" source="smartthings_exporter.go:180"
May 19 14:09:19 metrics.sachshaus.net smartthings_exporter[2457152]: time="2022-05-19T14:09:19Z" level=info msg="Build context (go=go1.15, user=, date=)" source="smartthings_exporter.go:181"
May 19 14:09:20 metrics.sachshaus.net smartthings_exporter[2457152]: time="2022-05-19T14:09:20Z" level=info msg="Listening on :9499" source="smartthings_exporter.go:214"
May 19 14:09:32 metrics.sachshaus.net systemd[1]: smartthings-exporter.service: Current command vanished from the unit file, execution of the command list won't be resumed.
May 19 14:09:33 metrics.sachshaus.net systemd[1]: Stopping The Smartthings Prometheus exporter service....
May 19 14:09:33 metrics.sachshaus.net systemd[1]: smartthings-exporter.service: Succeeded.
May 19 14:09:33 metrics.sachshaus.net systemd[1]: Stopped The Smartthings Prometheus exporter service..
May 19 14:09:33 metrics.sachshaus.net systemd[1]: Started The Smartthings Prometheus exporter service..
May 19 14:09:33 metrics.sachshaus.net smartthings_exporter[2457233]: time="2022-05-19T14:09:33Z" level=info msg="Starting smartthings_exporter (version=, branch=, revision=)" source="smartthings_exporter.go:180"
May 19 14:09:33 metrics.sachshaus.net smartthings_exporter[2457233]: time="2022-05-19T14:09:33Z" level=info msg="Build context (go=go1.15, user=, date=)" source="smartthings_exporter.go:181"
May 19 14:09:34 metrics.sachshaus.net smartthings_exporter[2457233]: time="2022-05-19T14:09:34Z" level=info msg="Listening on :9499" source="smartthings_exporter.go:214"
I’m happy to move this to another thread, but as it stands, the Github repo is locked down and I’m not sure of where else to ask for help in terms of narrowing down the issue with the exporter.
Edit
Looks like an issue with the Groovy app itself:
