Hi everyone,
I’ve built a simple Particle Photon remote temperature, humidity and heat index sensor/logger. Along with it, I’ve created a simple SmartThings device type to show these values in the app:
Check it out!
Hi everyone,
Check it out!
Thank you so much! I want to add this to my existing RF Switch transmitter / blind controller project. There’s so many I/O pins and RAM, why waste. Gotta get my $20 worth outta these boards.
@nicjansma Great Job!
I have been looking into this and I have a very similar use case as you do for this SmartApp and Sensor.
If you could provide greater detail and pictures of your build, it would be greatly appreciated! I would like to mimic this for monitoring my fermentation cycle in my chest freezer. Thank you!!!
Hi
Just wondering if you cud help
Have used https://github.com/nicjansma/smart-things/blob/master/devicetypes/nicjansma/spark-core-water-sensor/spark-core-water-sensor.groovy
but getting error
error groovyx.net.http.HttpResponseException: Not Found @105
Any Suggestions?
Cheers
