I made two new device types for the default SmartThings SmartSense
Temperature / Humidity Sensor. In both I added the capability to add a
icon and also add a offset for the humidity sensor.
This device type has the Humidity as the primary value for
displays and Temperature secondary. This was done for those wanting to display humidity without have a additional virtual device. The other uses the Temperature as the
primary value like the standard device type but with the additions above.
You can pull it from my GitHub ( vseven - SmartThings_VSeven - master ) or copy and paste from below.
