Projector Screen - Which ones will work?
(Lewis) #1
Hi all so I have taken a look at the custom device handler list but I can’t see any project screens on there:
http://thingsthataresmart.wiki/index.php?title=How_to_Quick_Browse_the_Community-Created_SmartApps_Forum_Section#Quick_Browse_Links_for_Device_Type_Handlers
Can anyone suggest a projector screen that I can control with ST or suggest a way that I can get a screen and swap out the relay or something like that? Someone must have done this before…
(ActionTiles.com co-founder Terry @ActionTiles; GitHub: @cosmicpuppy) #2
  1. If projector has RS-232 serial port (old technology, but still common), then it is a pretty easy Arduino project; if you want to tinker with hardware. That’s how mine works. I’m still using Thing Shield (no longer sold by SmartThings :cry:).
  2. If it has 12 volt trigger input (also very common), you could just plug a 12v power DC transformer into any smart outlet, and run the 12 volt output to the trigger input.
  3. If it has Ethernet/LAN/WiFi connection, then a Device Type Handler can likely be written to send the message via “Hub Action” commands; except there is no support for Telnet. In this case, Arduino or Pi could bridge the gap.
(ActionTiles.com co-founder Terry @ActionTiles; GitHub: @cosmicpuppy) #3
Ooops… My answers were more about Projectors, rather than Screens.
  • if it is radio controlled, you can use Arduino with a 433Mhz or ummmm… 328Mhz (whatever the common lower frequency is) to activate. My Projector Arduino does both the projector and the screen.
  • if it just has relays, you can drive a relay with 12 volt DC power transformer wall wort plugged into a SmartOutlet. Two may be required (up and down). Or use Arduino or ESP to control the two relays.
(Bernie H) #4
iIf it’s IR just use a Harmony.
If it’s RF like mine I just used a IR/dual relay(search the forum and full details are posted) and wired it into the remote or control box. Harmony has built in codes so it’s a breeze and only cost like $20 for the relay.
Or click here.
