Problems with Zigbee motion sensor mc driver
Hi Mariano:
Issue: Pairing Lidl Motion Sensor after it was removed in the Smartthings Android APP
I am having issues pairing one of my Lidl Motion Sensors via the app after it was removed. All my other Lidl sensors work fine.
LIDL Motion Sensor, manufacturer: _TZ1800_fcdjzz3s
Model: TY0202
Driver: Zigbee Motion Sensor MC
Adding a complete brand new Motion sensor from the same Brand/Model works fine.
Thanks for your help.
The most likely issue is that even though they look the same model, they have a different fingerprint.
Is this fingerprint from device that you are trying to pair?
Hello TapioX
Several months ago, I was able to pair this device with the Zigbee Motion Sensor MC driver.
A little later I removed it from the app, and now I cannot pair it.
Thanks, L
Hi @lucien
If you are sure that the fingerprints are the ones you published it should pair correctly.
Try pairing it with zigbee thing Mc to see the fingerprints
The “post requests for edge drivers” threads should typically only have two posts per device: one to make the request, and one for a developer to respond.
Please take any further discussion of features or problems with a custom edge driver either to the author thread for that edge Driver or start a new thread describing the issue.
Otherwise, the requests thread becomes unusable. :disappointed_relieved:
Thank you.
(I have moved your most recent discussion to this new thread.)
