Problems controlling vacation mode with Zwave Lock PH edge driver
Is it expected that you can turn on vacation mode through this driver but not be able to turn off vacation mode through the driver? Is this a common problem or just for me? I have only tried it recently and had to turn it off with the programming code at the Schlage 469 lock.
It works for me. When you switch Vacation mode ON, you can still enter codes, but they will be denied (:cross_mark:). After you turn OFF vacation mode, codes are accepted (:white_check_mark:). Just tested.
Thanks for testing.
Schlage locks are very finicky esp over z-wave. Their zwave chip has many requirements related to timings and order of commands.
If you’re still having an issue and have access to the rboy apps drivers try this one which has support to compensate these firmware quirks in schlage locks:
