Post Requests for Zwave Edge Drivers Here (community-created)
I have a few Honeywell T6-Pro Zwave thermostats that are being supported right now by the generic “Zwave Thermostat” “base thermostat” driver. I haven’t gotten to know it as well as I’d like, but at this point I see that it’s lacking a few Honeywell-specific functions. Schedule edit, and enable, is one.
I’m hoping to find one that utilizes the specific functions of the T6.
Fingerprint info:
Manufacturer Code
0039-0011-0008
Model
0011-0008
Thanks for any help!
Hello
I have this one:
Basically it is stolen Dome sensor:
https://docs.domeha.com/#motion-detector
With Kevin’s DTH, sensor worked perfectly, DTH was so simple to install.
With these jerks messing everything in 2024, it does pair as zwave motion, open/close, illuminance, temperature sensor but does not react to motion neither light or temperature changes.
Can anybody lead me step after step me how to make it working?
Edge drivers are so complicated, impossible to understand, how to install it?
Should work with @Mariano_Colmenarejo zwave-sensor.
You are welcome to try from Mariano Channel.
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
You originally posted your request in a Zigbee edge driver thread, but your device uses Z wave, so I have moved it to the Z wave request topic, and I see that someone has already answered you on that specific device. :sunglasses:
Additionally, it sounds like you might find the community FAQ on edge drivers helpful. They are certainly different than the old groovy DTH architecture, but they can actually be simpler to install and use. You just have to get used to the new process.
Anyway, read the first section of this FAQ and it should help:
FAQ: I have no idea what Edge is. Is that a new developer tool? (2022)
8 posts were split to a new topic: Problems with Neo Coolcam Zwave Sensor reports
I bought recently Honeywell thermostat T6 pro and tried 2 drivers:
  • Z-wave thermostat from smartthings drivers (Beta)
  • Z-wave thermostat from Mariano
Unfortunately both drivers didn’t work with me, would you please advice
  1. you posted in the Zigbee thread. Since this is a Z wave device, I have moved it to the Z wave thread.
  2. you will get the best answers about a driver if you post a question in the author’s thread for the specific driver that you tried. Not in the general driver request thread.
  3. please read the first post in this thread carefully. There is information that you need to include with your request, in particular, the fingerprint for your device, before anyone will be able to help you. :thinking:
Is there a good driver for Ring flood & freeze sensor and ring range extender v2?
@sdaltons Can you provide fingerprints
Please read the first post in this thread carefully, and then provide the information detailed there. It makes it much easier for the developers to help you.
Thanks, I understand the steps for requesting a new driver. I just wasn’t thinking that’s what I’d be doing here as both the devices in question have been around awhile and seem fairly common.
But I will go through the request process maybe.
Requesting a new driver and asking if there’s an existing driver that will work for a specific device are the same process. The fingerprint is what matters the most. You didn’t have to be this specific under the old groovy architecture because you could select a DTH even if there wasn’t a perfect match, but the edge drivers are really picky about it. :sunglasses:
I apologize in advance if this is posted in the wrong thread.
Anyway, I wonder if there is any edge driver available for Nexa Z-wave dimmer ZBD-110(Built-in dimmer)
Unfortunately I don’t have the fingerprints, and again, I don’t know if this is the place for questions like this. However, I find it really challenging figuring out whether there’s already an available driver for a specific device. So any tips or input in this is much appreciated
I was told to post to this thread. I have a Schlage door/window sensor. It keeps trying to add smoke and water sensor. I have reloaded it a number of times. The model is showing as 0001-0002.
Code is 011F-0001-0002
Driver is Zwave sensor
I have no coding knowledge so any help in getting it to work just as a window sensor would be appreciated.
Rick
There is no specific fingerprint for that device in the stock drivers so it defaults to a generic profile which includes the additional capabilities. Hopefully, @csstup can add that fingerprint to his Z-Wave Sensor CS driver and map it to a simple open/closed contact sensor profile.
The fingerprint posted is helpful, but also need to know the exact model number to get the specific capabilities of this device.
The model is Schlage DWZWAVE1
fcc id XQC-DWZ1
ic 9863B-DWZ1
Rick
Also listed as ZM3102 on the Z-Wave Alliance website. Supported controlled command classes are only Basic.
https://products.z-wavealliance.org/products/647?selectedFrequencyId=2
The ZM3102 is the platform, aka chipset. It was a SoC with a 8051 series CPU and 300 series zwave radio all in one. Lots of products used it, so that doesn’t help with the specific implementation for this contact sensor.
The alliance link you posted is to the Schlage motion sensor, not the contact sensor. Just to reduce confusion, I had to double check when I thought for sure it was a door/window sensor being inquired about.
Ah
Sorry about that. Link updated in my post.
