Post Requests for Zwave Edge Drivers Here (community-created)
The driver updated overnight and is now on the right version and working. Thank you very much!
Were you able to find a driver for the Hank SO03 smart plug? I have one of these with a Zooz label on it but Hank/Monoprice firmware and I can’t find an Edge driver for it.
Posting an Edge driver request for the Telldus TZWP-102 Z-wave metering switch.
My z-wave devices NoDon Micro Smart Plug NODEMSP3101 and Neo Coolcam Smart Power Plug Socket outlets does not pick up any edge drivers. But it all works with the original dth-drivers (Z-Wave Metering Switch). Can someone please help add these fingerprints.
Nodon Micro Smart Plug:
zw:L type:1001 mfr:0165 prod:0001 model:0003 ver:1.07 zwv:4.05 lib:03 cc:5E,27,85,59,25,70,5A,87,72,71,73,75,32,7A,86
Neo Coolcam Smart Power Plug Socket:
zw:L type:1001 mfr:0258 prod:0200 model:1027 ver:2.23 zwv:6.04 lib:03 cc:5E,98,9F,55,73,86,85,8E,59,72,5A,25,32,71,70,6C
I couldn’t find a driver and didn’t care to wait, so I did it myself. I forked and cloned the community driver repo and added these fingerprints to zwave-switch/fingerprints.yml:
  - id: 0208/0101/0005
    deviceLabel: Hank SO01 smart plug
    manufacturerId: 0x0208
    productType: 0x0101
    productId: 0x0005
    deviceProfileName: metering-switch
  - id: 0208/0101/000A
    deviceLabel:  Hank SO03 smart plug
    productType: 0x0101
    productId: 0x000A
Next I installed the updated zwave-switch driver on my hub (instructions here)… I excluded/included my SO01 and SO03 switches, and they now appear with the deviceLabels above, as Edge Z-Wave devices. They handle on/off commands and report power usage. I didn’t try to add any settings.
I have one fingerprint pull request pending for that repo - I’m waiting to see if I get any feedback on whether I submitted it properly - but apparently that doesn’t happen in a timely manner… If that goes through I’ll submit these Hank fingerprints.
My guess is that if you wait for SmartThings to handle all this automatically, your Hank switches will get metering-switch support. If you require access to settings, try the Mariano Colmenarejo Z-Wave Device Config Mc driver.
For the record, the two Hank switches have the same parameters:
   '#'  Bytes Default Desc
   20   1       1   overload protection            0=disabled, 1=enabled (16.5A for 5s)
   21   1       0   after power failure            0=previous 1=on 2=off
   24   1       1   load status change             0=disable 2=basic 3=if change not by Z-Wave command
   27   1       0   LED always follows load        0=hold  1=5 seconds only
   151  2       0   power report threshold         0=disable, 1-65535 W
   152  1       0   percent threshold power report 0=disable, 1-255%
   171  4       0   power report frequency         0=disabled, 5-2678400s
   172  4       0   energy report frequency        0=disabled, 5-2678400s
   173  4       0   voltage report frequency       0=disabled, 5-2678400s
   174  4       0   electricity report frequency   0=disabled, 5-2678400s
I’m not sure what ā€œelectricityā€ reports - maybe current in amperes?
Jonathan, does your Hank driver display voltage and current?
Power (watts) and Energy (watt-hours) are displayed, and appear to be correct or at least reasonable.
I didn’t create a driver - I just connected the Hank switch to the ā€œmetering-switchā€ driver in the SmartThingsCommunity/SmartThingsEdgeDrivers. Power reporting is handled by that driver without any modification.
That’s why I suggest that you will (eventually) get on/off and power reporting support from the SmartThings migration.
Anyone knows if there’s any Fortrezz MIMO2+ edge driver? Saw the driver for MIMO lite only.
I have a device that I think is an older inovelli dimmer or switch outlet (admittedly, I’m not sure as I only use it as a switch). I’m guessing it will pair with the stock driver but I don’t see the finger print in the beta driver yet. Can anyone add this fingerprint or advise if it’s likely to work?
zw:L type:1101 mfr:015D prod:2700 model:2700 ver:1.01 zwv:4.61 lib:03 cc:5E,26,27,70,5B,85,8E,59,55,86,72,5A,73,9F,6C,7A role:05 ff:8601 ui:8600
I would like to request a Edge driver for the Sureflap Pet Connect pet door. There was a custom DH for it in GitHub, but one day it suddenly disappeared from my list of devices in ST. I have both the door and the hub. I’m not sure what other information would be needed for this.
Having this working again would be great since both of us are handicapped.
Still doesnt see any driver for
Xiaomi Mijia Honeywell Fire Detector
Govee light (was using Govee LED Strips (DBDEV))
Any ideas ?
What would be really awesome is if someone were to create an app that could take a DTH as input and produce a corresponding Edge driver. Should really be something Samsung provided as part of the platform change.
And, yes, I do realise this is probably impractical, and would replicate a lot of what is provided in the stock drivers. Just a dream, really.
We need Edge drivers creating for around 15 devices (already working in Groovy).
Looking for a paid developer, so message me if interested
Hi there. Please can you assist me in getting the flush 2 relay to work. I’ve set the master device and two child devices that were created to Z-wave switch in IDE but still can’t operate either (master works)
Does somebody know is there a plan for Tapo P110 Edge driver? Tp-link ST C2C integration is not working, at least energy consumption part is not working. Only on/off is ok.
It’s not broken, the official Tp-link ST C2C integration never brought energy consumption into SmartThings.
for me it’s broken :slight_smile: I’m kidding, but it’s not working as I hoped to. And you know, it’s such a pain to spent few hours of time just to find product that will actually do what you want. And at the end, feature you needed is not working.
Good morning, @veonua @ygerlovin @Benjamin_Ginders could you please add the fingerprint of the Temperature, Humidity and Illuminance (Lux) zigbee sensor from Moes (Tuya platform). Attached is the fingerprint of this sensor and also the link of the device sold on aliexpress:
https://www.aliexpress.us/item/3256802349586974.html?gps-id=pcFullPieceDiscount&scm=1007.24625.271276.0&scm_id=1007.24625.271276.0&scm-url=1007.24625.271276.0&pvid=57ec7cf2-7b1a-44dc-bde3-f6deec0a0f44&_t=gps-id%3ApcFullPieceDiscount%2Cscm-url%3A1007.24625.271276.0%2Cpvid%3A57ec7cf2-7b1a-44dc-bde3-f6deec0a0f44%2Ctpp_buckets%3A668%232846%238113%231998&pdp_ext_f={"sku_id"%3A"12000021040673906"%2C"sceneId"%3A"14625"}&pdp_npi=2%40dis!BRL!109.0!75.2!!!!!%402103222716677442164165645ea400!12000021040673906!rec&spm=a2g0o.store_pc_home.fullPieceDiscountPromo_2003452692289.1005002535901726&gatewayAdapt=glo2usa&_randl_shipto=US
My request is for the Philips Go and Philips Bloom lights. I don’t have a specific id, as they use DTH defaults ZigBee RGBW Bulb:
  • endpointId: 0B
  • firmwareFullVersion: 01001600
  • firmwareImageType: 279
  • firmwareManufacturerCode: 4107
  • manufacturer: Philips
  • model: 7602031U7
  • zigbeeNodeType: ROUTER
  • application: 02
  • endpointId: 0B
  • model: 929002376501
Good evening, @Mariano_Colmenarejo could you please add the fingerprint of the Moes display temperature and humidity sensor (model: KCTW1Z-02) from the Tuya platform to the Zigbee Temp Humidity Sensor MC driver and the other temperature and humidity sensor drivers. Attached is the fingerprint print of the Sensor and the aliexpress product link:
https://www.aliexpress.us/item/3256804145193869.html?spm=a2g0o.order_list.0.0.69a6caa4W3NaEN&gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
