Post Requests for Zigbee Edge Drivers Here (community-created)
Mariano is no longer contributing to the community
Have you tried the official sonoff edge driver?
Source:
Thank you for pointing this out. I had found your earlier post and already subscribed to the driver. It still works.
But I am trying to write a routine to shut my food dehydrator off at 150 degrees. You likely know that the Smartthings limit for temperature in routines is 122 degrees. So even cheating with an offset won’t work. The virtual thermostat allows me to trigger my smart plug from the thermostat heating state, so I can use a higher temperature for my routing.
Maybe there’s another way, if anyone knows please share.
You can copy using Rules API temperature value to virtual temperature device.
Maybe the virtual temperature measurement range is larger.
I haven’t used the vEdge driver anymore.
Maybe this Rules API rule still works.
Thank you. I have the vEdge Creator installed and have created a vEdge Temp sensor, but I cannot see a way to have it mirror my Sonoff Temp sensor. I’ve been searching around and it appears I have to do that on Developer page with rules API or something like that. I haven’t done that before and not going to take that on today. If there is a simple way please let me know.
Read the whole thread:
Maybe perform this rule using @joshua_lyon rule engine? There are no limits there and you can also define variable if needed. Give it a try
Anybody knows a working edge driver link to:
lumi.remote.acn004
I hace tried several without success :frowning:
-Marko
Hi @Mariano_Colmenarejo,
​Could you please add this Zigbee Keyfob/Remote to your driver? It is a 4-button remote (Nedis) but it seems to expose IAS Zone clusters, so it might need to be in the Button or Sensor driver.
​Here are the details from the device:
  • Manufacturer: _TZ3000_fsiepnrh
  • Model: TS0215A
  • Device ID: 0x0401
  • Fingerprint:
    • Server Clusters: 0x0001 (PowerConfig), 0x0500 (IAS Zone), 0x0501 (IAS ACE), 0x0000 (Basic)
    • Client Clusters: 0x000A (Time), 0x0019 (OTAUpgrade)
​Thank you for your help!
Looks like a simple remote. You can ask @zambobmaz to add this to his driver. Open and issue him in his Github here:
https://github.com/obmaz/smartthings_edge_driver
Unfortunately it was incompatible with obmaz drivers. Got the device paired with them but the buttons don’t work.
The manufacturer ID of the device is from Tuya, if you know of a driver bundle for that?
You can try this Generic Tuya Drive, from w35l3y:
[ST Edge] Personal Tuya Devices - Generic EF00 Device
Or Erick’s:
[ST Edge] Zigbee Driver for MOES 4-Button Scene Switch (TS004F) Plus Some Smart Knob Models
Good evening everyone,
Just in case, I published the fingerprint at the development channel. You can get the details at this repo: GitHub - erickvneri/erickv-edge-drivers at develop
Or Click Here to enroll your Hub in the channel and install the button-battery-v1.4.5
Could you please add this Zigbee MOES Scene Switch (2 button) to your driver?
Manufacturer _TZ3000_xr7itfxq
Model TS0042
Endpoint 0x01
-Ep:0x01={ 0001,0006,E000,0000 }-Ep:0x02={ 0006,0001,0006 }-Ep:0x03={ 0006,0001,0006 }-Ep:0x04={ 0006,0001,0006 }
App Version: Unknown, ZCL Version: Unknown
FingerPrinted_EndPoint.Id: 0x01
TS0042
_TZ3000_xr7itfxq
Already include on @zambobmaz devices. Use his driver:
https://api.smartthings.com/invitation-web/accept?id=2d6da83b-ae22-4fda-8af5-bbb8890872d4
Works perfectly! Thanks!
Gentlemen
I need a Zigbee driver for Sonoff Zigbee valve, as it shows in smartthings app as a thing only.
Thank you guys, no more action required.
I tried “Zigbee Valve mc” from Mariano channel.
Thanks a lot @Mariano_Colmenarejo
You can also see if there is an sonoff oficial driver:
SONOFF Products Integration Guide for SmartThings & Driver Installatio
I have a 4 in 1 ZG-204ZV, ST recognizes it with just motion sensor and illuminance and not temperature and humidity. There’s a delay when shutting off motion also. Is there an edge driver to support all four functions?
Towards the bottom of this page someone has come up with a driver for another hub, maybe this would help to develop one for ST if one doesn’t exist. [Device Support Request] HOBEIAN ZG-204ZG · Issue #4268 · zigpy/zha-device-handlers · GitHub
Manufacturer:HOBEIAN Model:ZG-204ZV
With Zigbee Thing Mc driver it shows this info.
FingerPrinted_EndPoint.Id: 0x01 App Version: 0x93
ZCL Version: 0x03
Server Cluster: Ep: 0x01={ 0000,0003,0500,EF00,0402,0405,0001, 0400 }
Client Clusters: Ep: 0x01={ 0003 }
