Porch Light - On a few hours before Sunrise
I’m new to Smart Things and just received my new v2.0 hub,
I’m looking to Automate the Porch light.
Turn on at Sunset
Turn off at 10PM.
Turn on 2 Hours before RunRise
Turn Off at Sunrise
Turn on for an Hour if after 10PM and Mobile Device is Approaching.
So Far I’m stumbling on the 2 Hours before Sunrise.
Any Suggestions? Thanks!
So for the ones involving sunrise/sunset I would use the routines built into the app it has offsets before and after sunrise/sunset. For the rest I would use SimpleRuleBuilder.com
Good luck!
Most of these can be done with the Smart Lighting smart app. You need separate rules for each on and off point.
Note: I think that a negative sign in the offset is correct to do before sunrise, but I am not entirely certain.
This is the tricky one. I don’t think it can be done with Smart Lighting. I can get as far as turning on the light upon arrival between 10pm and sunrise, but there’s no way to shut it off an hour later. This would probably need a smart app. You can check the marketplace to see if anything exists that would work, or try a rule builder as mentioned above.
I would probably do as much as possible with Smart Lighting, so that you can get as much local processing as possible.
Yea that’s why I stay with SimpleRuleBuilder. As many “AND’s” & “OR’s” as I need.
Awesome. I think I have it all. I must of Missed the Sunrise Offset when I went though it before. So far I just have the Manual off if I ‘Arrive’ after 10. I’ll have to check out the SimpleRuleBuilder.
Thank you!
