Automations and combining starting at sunet and ending at a certain time
I am trying to move from the smart lighting app to Automations but am stuck. I am trying to have my porch light come on at sunset and off at 10:30. When trying to set up an automation, I can only choose a time or sunrise/sunset, not a combination.
how are you all handling automating this?
the smartlighting app seemed easier to me than automations are for some reason.
Hi, @chrisrose98
With the Rules API you can create flexible and customizable automations. Please, check the example at this post, which describes the following workflow:
  • If Now is between Sunset and Sunrise,
  • Then Turn On the switch device.
For your use-case, the Rule should be modified as following:
                "end": {
                	"time": {
                    	"timeZoneId": "{{yourZoneId}}",
                		"reference": "Sunrise",
                        "offset": {
                            "value": "270",      <-- 270 Minutes after Sunrise
                            "unit": "Minute"
            "then": [
                    "command": {
                        "devices": [
                            "{{yourDeviceId}}"
                        "commands": [
                                "component": "main",
                                "capability": "switch",
                                "command": "on",
                                "arguments": []
Also, you can find instructions on how to install your Rule at this thread.
I’ve got this! I’ve got it set in two automations, actually.
My “sunset trigger ON” turns the living room lamp on twenty minutes before sunset. (At Christmas, I add the Christmas tree switch to this automation.)
Then, I have a “living room OFF” automation, which turns off everything at 10pm, and signals me to go to bed. (There are a few other lights that come on during the evening to signal what time it is for me.)
I kind of like it in two automations, because I can add/subtract things to each side depending on the time of the year and the stuff I have come on.
Thanks. That’s what I ended up doing with my porch light. How about this other close but more complex one.
Same light. After 10:30 I want it off but I want it to come on, triggered by the motion sensor when someone, my kids, get home after 10:30. I want it to come on, based on motion, then turn off after 5 min for them to get inside, and this whole automation to stop at sunrise. I got the on with motion but is the “end time “ automation just an “off” for the light at sunrise?
Chris
This one you may not be able to do. I have the same issue with my kitchen. I would love to be able to have the motion sensor kick on the lights at sunset and stop working at 9pm, but I couldn’t get it. So I have it as below, and during the summer I set the starting time later. During the winter, I have it set an hour earlier. It’s not as “never have to touch again”, but touching it twice a year hasn’t been too awful so far.
I have it working perfectly using the old smart lighting App but thought I’d play the game with smartthings and try it the new way.
