Popp Z-Wave Solar Siren
So Im not a programmer by any stretch and I didn’t like the limited nature of the device handlers out there so I wrote this. it has the correct parameters for the device for a start and it also shows battery and temperature
 *	POPP Z-Wave Solar Siren
 *	Author: Tapion1ives
 *	Date: 2018-11-21
 *  Desc: So i took the aeon Siren dth and the generic z wave dth and i smooshed them both together and     here we are.
* im a data analyst specialising in sql reporting, so this isnt really my bag, the only way i could get the parameters to set was by making it refresh. but it works so wuhooo
metadata {
definition (name: "POPP Z-Wave Solar Siren", namespace: "Tapion1ives", author: "tapion1ives", ocfDeviceType: "x.com.st.d.siren", runLocally: false, minHubCoreVersion: '000.017.0012', executeCommandsLocally: false) {
capability "Actuator"
capability "Alarm"
capability "Switch"
capability "Health Check"
capability "Polling"
capability "Refresh"
capability "Temperature Measurement"
capability "Sensor"
capability "Battery"
command "test"
fingerprint mfr: "0154", prod: "0004", model: "0002", deviceJoinName: "Popp Solar Siren"
 simulator {
// reply messages
reply "9881002001FF,9881002002": "command: 9881, payload: 002003FF"
reply "988100200100,9881002002": "command: 9881, payload: 00200300"
reply "9881002001FF,delay 3000,988100200100,9881002002": "command: 9881, payload: 00200300"
 tiles(scale: 2) {
multiAttributeTile(name:"alarm", type: "generic", width: 6, height: 4){
	tileAttribute ("device.alarm", key: "PRIMARY_CONTROL") {
		attributeState "off", label:'off', action:'alarm.siren', icon:"st.alarm.alarm.alarm", backgroundColor:"#ffffff"
		attributeState "both", label:'alarm!', action:'alarm.off', icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
standardTile("test", "device.alarm", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
	state "default", label:'', action:"test", icon:"st.secondary.test"
standardTile("off", "device.alarm", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
	state "default", label:'', action:"alarm.off", icon:"st.secondary.off"
  standardTile("refresh", "command.refresh", inactiveLabel: false,
                         decoration: "flat") {
                    state "default", label:'', action:"refresh.refresh",
                          icon:"st.secondary.refresh"
            valueTile("battery", "device.battery", inactiveLabel: false,
                    state "battery", label:'${currentValue}% battery', unit:""
            valueTile("temperature", "device.temperature") {
                    state("temperature", label:'${currentValue}°',
                            backgroundColors:[
                                    [value: 31, color: "#153591"],
                                    [value: 44, color: "#1e9cbb"],
                                    [value: 59, color: "#90d2a7"],
                                    [value: 74, color: "#44b621"],
                                    [value: 84, color: "#f1d801"],
                                    [value: 95, color: "#d04e00"],
                                    [value: 96, color: "#bc2323"]
preferences {
	// here we will set the preferences as variables to pass through on configuration and update
	input "tamper", "integer", title: "Siren Tamper Mode" , defaultValue: 0, required: false//, displayDuringSetup: true
    input "tempadj", "integer", title: "Temperature Adjustment" , defaultValue: 0, required: false//, displayDuringSetup: true
    input "temprep", "integer", title: "Send unsolicited Temperature Report" , defaultValue: 10, required: false//, displayDuringSetup: true
    input "tempperiod", "integer", title: "Send unsolicited Temperature Report periodically " , defaultValue: 15, required: false//, displayDuringSetup: true
    input "mode", "integer", title: "Siren Mode",  defaultValue: 2, required: false//, displayDuringSetup: true
    input "autooff", "integer", title: "Auto Off in mins", defaultValue: 5, required: false//, displayDuringSetup: true
main (["alarm", "temperature"])
details(["alarm", "test", "off", "temperature", "refresh", "battery"])
log.debug "parse($description)"
def result = null
if (description.startsWith("Err")) {
	if (state.sec) {
		result = createEvent(descriptionText:description, displayed:false)
	} else {
				descriptionText: "This device failed to complete the network security key exchange. If you are unable to control it via SmartThings, you must remove it from your network and add it again.",
				eventType: "ALERT",
				value: "failed",
				displayed: true,
} else {
	def cmd = zwave.parse(description, [0x98: 1, 0x20: 1, 0x70: 1])
	if (cmd) {
		result = zwaveEvent(cmd)
log.debug "Parse returned ${result?.inspect()}"
return result
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x85: 2, 0x70: 1])
// log.debug "encapsulated: $encapsulatedCommand"
if (encapsulatedCommand) {
	zwaveEvent(encapsulatedCommand)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
log.debug "rx $cmd"
	createEvent([name: "switch", value: cmd.value ? "on" : "off", displayed: false]),
	createEvent([name: "alarm", value: cmd.value ? "both" : "off"])
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
    def result
    if (cmd.scale == 0) {
            result = createEvent(name: "energy", value: cmd.scaledMeterValue,
                                 unit: "kWh")
    } else if (cmd.scale == 1) {
                                 unit: "kVAh")
    } else {
            result = createEvent(name: "power",
                                 value: Math.round(cmd.scaledMeterValue), unit: "W")
    result
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
    def map = null
    if (cmd.meterType == 1) {
                    map = [name: "energy", value: cmd.scaledMeterValue,
                           unit: "kWh"]
                           unit: "kVAh"]
            } else if (cmd.scale == 2) {
                    map = [name: "power", value: cmd.scaledMeterValue, unit: "W"]
            } else {
                    map = [name: "electric", value: cmd.scaledMeterValue]
                    map.unit = ["pulses", "V", "A", "R/Z", ""][cmd.scale - 3]
    } else if (cmd.meterType == 2) {
            map = [name: "gas", value: cmd.scaledMeterValue]
            map.unit =      ["m^3", "ft^3", "", "pulses", ""][cmd.scale]
    } else if (cmd.meterType == 3) {
            map = [name: "water", value: cmd.scaledMeterValue]
            map.unit = ["m^3", "ft^3", "gal"][cmd.scale]
    if (map) {
            if (cmd.previousMeterValue && cmd.previousMeterValue != cmd.meterValue) {
                    map.descriptionText = "${device.displayName} ${map.name} is ${map.value} ${map.unit}, previous: ${cmd.scaledPreviousMeterValue}"
            createEvent(map)
    } else {
            null
 def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
    def result
    switch (cmd.sensorType) {
            case 2:
                    result = createEvent(name:"smoke",
                            value: cmd.sensorValue ? "detected" : "closed")
                    break
            case 3:
                    result = createEvent(name:"carbonMonoxide",
                            value: cmd.sensorValue ? "detected" : "clear")
                    break
            case 4:
                    result = createEvent(name:"carbonDioxide",
                    break
            case 5:
                    result = createEvent(name:"temperature",
                            value: cmd.sensorValue ? "overheated" : "normal")
                    break
            case 6:
                    result = createEvent(name:"water",
                            value: cmd.sensorValue ? "wet" : "dry")
                    break
            case 7:
                            value: cmd.sensorValue ? "freezing" : "normal")
                    break
            case 8:
                    result = createEvent(name:"tamper",
                            value: cmd.sensorValue ? "detected" : "okay")
                    break
            case 9:
                    result = createEvent(name:"aux",
                            value: cmd.sensorValue ? "active" : "inactive")
                    break
            case 0x0A:
                    result = createEvent(name:"contact",
                            value: cmd.sensorValue ? "open" : "closed")
                    break
            case 0x0B:
                    result = createEvent(name:"tilt", value: cmd.sensorValue ? "detected" : "okay")
                    break
            case 0x0C:
                    result = createEvent(name:"motion",
                    break
            case 0x0D:
                    result = createEvent(name:"glassBreak",
                    break
            default:
                    result = createEvent(name:"sensor",
                    break
    result
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
    // Version 1 of SensorBinary doesn't have a sensor type
    createEvent(name:"sensor", value: cmd.sensorValue ? "active" : "inactive")
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
    def map = [ displayed: true, value: cmd.scaledSensorValue.toString() ]
            case 1:
                    map.name = "temperature"
                    map.unit = cmd.scale == 1 ? "F" : "C"
                    break;
            case 2:
                    map.name = "value"
                    map.unit = cmd.scale == 1 ? "%" : ""
                    break;
            case 3:
                    map.name = "illuminance"
                    map.value = cmd.scaledSensorValue.toInteger().toString()
                    map.unit = "lux"
                    break;
            case 4:
                    map.name = "power"
                    map.unit = cmd.scale == 1 ? "Btu/h" : "W"
                    break;
            case 5:
                    map.name = "humidity"
                    map.unit = cmd.scale == 0 ? "%" : ""
                    break;
            case 6:
                    map.name = "velocity"
                    map.unit = cmd.scale == 1 ? "mph" : "m/s"
                    break;
            case 8:
            case 9:
                    map.name = "pressure"
                    map.unit = cmd.scale == 1 ? "inHg" : "kPa"
                    break;
            case 0xE:
                    map.name = "weight"
                    map.unit = cmd.scale == 1 ? "lbs" : "kg"
                    break;
            case 0xF:
                    map.name = "voltage"
                    map.unit = cmd.scale == 1 ? "mV" : "V"
                    break;
            case 0x10:
                    map.name = "current"
                    map.unit = cmd.scale == 1 ? "mA" : "A"
                    break;
            case 0x12:
                    map.name = "air flow"
                    map.unit = cmd.scale == 1 ? "cfm" : "m^3/h"
                    break;
            case 0x1E:
                    map.name = "loudness"
                    map.unit = cmd.scale == 1 ? "dBA" : "dB"
                    break;
    createEvent(map)
createEvent(displayed: false, descriptionText: "$device.displayName: $cmd")
def on() {
log.debug "sending on"
	secure(zwave.basicV1.basicSet(value: 0xFF)),
	secure(zwave.basicV1.basicGet())
def off() {
log.debug "sending off"
	secure(zwave.basicV1.basicSet(value: 0x00)),
def strobe() {
on()
def siren() {
on()
def both() {
on()
def test() {
	"delay 3000",
def refresh() {
    // Some examples of Get commands
    delayBetween([
            zwave.switchBinaryV1.switchBinaryGet().format(),
            zwave.switchMultilevelV1.switchMultilevelGet().format(),
            zwave.meterV2.meterGet(scale: 0).format(),      // get kWh
            zwave.meterV2.meterGet(scale: 2).format(),      // get Watts
            zwave.sensorMultilevelV1.sensorMultilevelGet().format(),
            zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType:1, scale:1).format(),  // get temp in Fahrenheit
            zwave.batteryV1.batteryGet().format(),
            zwave.basicV1.basicGet().format(),
            secure(zwave.configurationV1.configurationSet(parameterNumber:1, size:1, configurationValue:[settings.tamper.toInteger()])),
			secure(zwave.configurationV1.configurationSet(parameterNumber:2, size:1, configurationValue:[settings.tempadj.toInteger()])),
            secure(zwave.configurationV1.configurationSet(parameterNumber:3, size:1, configurationValue:[settings.temprep.toInteger()])),
            secure(zwave.configurationV1.configurationSet(parameterNumber:4, size:2, configurationValue:[settings.tempperiod.toInteger()])),
            secure(zwave.configurationV1.configurationSet(parameterNumber:5, size:1, configurationValue:[settings.mode.toInteger()])),
            secure(zwave.configurationV1.configurationSet(parameterNumber:6, size:3, configurationValue:[settings.autooff.toInteger()])),
            secure(zwave.configurationV1.configurationGet(parameterNumber:1)),
			secure(zwave.configurationV1.configurationGet(parameterNumber:2)),
			secure(zwave.configurationV1.configurationGet(parameterNumber:3)),
			secure(zwave.configurationV1.configurationGet(parameterNumber:4)),
			secure(zwave.configurationV1.configurationGet(parameterNumber:5)),
			secure(zwave.configurationV1.configurationGet(parameterNumber:6)),
    ], 1200)
private secure(physicalgraph.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
 // If you add the Configuration capability to your device type, this
// command will be called right after the device joins to set
 // device-specific configuration commands.
def configure() {
 log.debug "configuring"
def installed() {
// Device-Watch simply pings if no device events received for 32min(checkInterval)
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
// Get default values and set device to send us an update when alarm state changes from device
 refresh()
def updated() {
def commands = []
  log.debug "updating"
response(commands)
 *	Date: 2018-11-21
 *  v1.00
 * v1.01  : changed preferences so they are dropdowns  made it so updating preferences actually sends that over to the device
metadata {
	capability "Alarm"
	capability "Switch"
    capability "Sensor"
	command "test"
 simulator {
	// reply messages
 tiles(scale: 2) {
                                backgroundColors:[
	preferences {
		input name: "tamper", type:"enum", title: "Siren Tamper Mode" ,options:[0: "Allow Siren off from app", 1: "Require back on plate for stop", 2: "Disable Tamper"],  required: true, description: "Enter enum"//, displayDuringSetup: true
        input name: "tempadj", type:"enum", title: "Temperature Adjustment" , required: true ,options:[0: "Nothing", 127: "+0.1k", 255: "-0.1k"]//, displayDuringSetup: true
        input name: "temprep", type:"number", title: "Send unsolicited Temperature Report" , defaultValue: 10, required: false//, displayDuringSetup: true
        input name: "tempperiod",type: "number", title: "Send unsolicited Temperature Report periodically 1 = 4minutes " , defaultValue: 15, required: false//, displayDuringSetup: true
        input name:  "mode", type:"enum", title: "Siren Mode",  defaultValue: 2, required: true,options:[0: "Siren", 1: "Strobe only", 2: "Both"]//, displayDuringSetup: true
        input name: "autooff", type:"number", title: "Auto Off in mins", defaultValue: 5, required: false//, displayDuringSetup: true
def installed() {
 refresh()
def updated() {
	def commands = [secure(zwave.configurationV1.configurationSet(parameterNumber:1, size:1, configurationValue:[settings.tamper.toInteger()])),
				secure(zwave.configurationV1.configurationGet(parameterNumber:6)),]
	response(commands)
	def result = null
		if (state.sec) {
		} else {
					eventType: "ALERT",
					value: "failed",
					displayed: true,
	} else {
        def cmd = zwave.parse(description, [0x98: 1, 0x20: 1, 0x70: 1,0x80: 1])
        if (cmd) {
                log.debug "Parsed ${cmd} to ${result.inspect()}"
        } else {
                log.debug "Non-parsed event: ${description}"
	return result
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
        def map = [ name: "battery", unit: "%" ]
        if (cmd.batteryLevel == 0xFF) {  // Special value for low battery alert
                map.value = 1
                map.descriptionText = "${device.displayName} has a low battery"
                map.isStateChange = true
        } else {
                map.value = cmd.batteryLevel
        // Store time of last battery update so we don't ask every wakeup, see WakeUpNotification handler
        state.lastbatt = new Date().time
        createEvent(map)
	log.debug "rx $cmd"
        def result
                                     unit: "kWh")
                                     unit: "kVAh")
        } else {
        result
        def map = null
                               unit: "kWh"]
                               unit: "kVAh"]
                } else {
        if (map) {
                createEvent(map)
        } else {
                null
        def result
                case 2:
                        break
                case 3:
                        break
                case 4:
                        break
                case 5:
                        break
                case 6:
                        break
                case 7:
                        break
                case 8:
                        break
                case 9:
                        break
                case 0x0A:
                        break
                case 0x0B:
                        break
                case 0x0C:
                        break
                case 0x0D:
                        break
                default:
                        break
        result
                case 1:
                        break;
                case 2:
                        map.name = "value"
                        break;
                case 3:
                        map.unit = "lux"
                        break;
                case 4:
                        map.name = "power"
                        break;
                case 5:
                        break;
                case 6:
                        break;
                case 8:
                case 9:
                        break;
                case 0xE:
                        map.name = "weight"
                        break;
                case 0xF:
                        break;
                case 0x10:
                        break;
                case 0x12:
                        break;
                case 0x1E:
                        break;
        createEvent(map)
def on() {
def off() {
def strobe() {
	on()
def siren() {
	on()
def both() {
	on()
def test() {
		"delay 3000",
def refresh() {
        delayBetween([
                 zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType:2, scale:1).format(),
        ], 1200)
def ping() {
def configure() {
So I made some changes to this code with dropdowsn in the preferences and also I amade it so the update bit actually works
so things we could do if we wanted is actually have a dedicated strobe button and a dedicated alarm only button
and I don’t like the way the aeon alarm reports its status but its functional now so im only gonna do that if someone else asks cos I don’t really care
hey man ,can you post some screenshots of how it looks inside the smartthings menu?
can i control with this the strobe and siren independently ? thanks
Kind of But not really, there is a parameter for setting it to strobe only or siren only or both.
So you would have to send the parameter first then activate the siren. Which I suppose you could adapt the device handler to do with one button but I doubt I’ll have time to
