Just moved from CoRE to WebCORE. Nice.
Only had 2 pistons running on CoRE and they are simple. A Philips Hue button which is registering perfect, when pressed, triggers a GE Wall switch to turn off and on. Basically a remote control switch across the room. Easy as it gets.
I put in the code and love the new interface but the remote isn’t sending the command to the GE switch. I keep getting “waiting at a sephamore” and nothing happening even though the piston sees me pressing the Hue button.
10/25/2018, 12:34:44 PM +494ms
+1ms ╔Received event [Hue Dimmer Switch (ZHA)].button = released_off with a delay of 86ms
+10260ms ║RunTime Analysis CS > 24ms > PS > 10216ms > PE > 21ms > CE
+10262ms ║Piston waited at a semaphore for 10135ms
+10264ms ║Runtime (36764 bytes) successfully initialized in 10216ms (v0.3.108.20180906) (10262ms)
+10265ms ║╔Execution stage started
+10277ms ║║Comparison (enum) released_off gets (string) pushed = false (1ms)
+10280ms ║║Condition #2 evaluated false (7ms)
+10281ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+10283ms ║╚Execution stage complete. (18ms)
+10285ms ╚Event processed successfully (10285ms)
10/25/2018, 12:34:41 PM +330ms
+2ms ╔Received event [Hue Dimmer Switch (ZHA)].button = pushed_on with a delay of 93ms
+10245ms ║RunTime Analysis CS > 22ms > PS > 10185ms > PE > 37ms > CE
+10246ms ║Piston waited at a semaphore for 10099ms
+10248ms ║Runtime (36762 bytes) successfully initialized in 10185ms (v0.3.108.20180906) (10245ms)
+10249ms ║╔Execution stage started
+10260ms ║║Comparison (enum) pushed_on gets (string) pushed = false (1ms)
+10262ms ║║Condition #2 evaluated false (6ms)
+10264ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+10266ms ║╚Execution stage complete. (17ms)
+10268ms ╚Event processed successfully (10267ms)
I am sure I am missing something obvious here. What is it?
