Some help with the below would be greatly appreciated before i pull all my hair out .
I would like a light to be turned on when the location mode is set to X then wait for Y seconds and turn off. The issue that i’m having is that the “wait” counts down from Y seconds to zero, i get a red “pending” notification then, the timer counts up indefinitely and the light doesn’t turn off. The frustrating part is that i did have it working before the latest update where, in all of the updating excitement, i deleted all my pistons. Doh!!
In the attached piston you can see both methods that i have tried… Post update i get “Waited at a semaphore” a lot which i didn’t notice before? I am a noob so may be missing something obvious but, like i say, i did have it working on a previous piston.
Thanks for the help
#backupyourpistons
5/26/2019, 11:11:23 PM +750ms
+2ms ╔Received event [Hue Motion Sensor (Hall)].motion = inactive with a delay of 76ms
+95ms ║RunTime Analysis CS > 29ms > PS > 40ms > PE > 26ms > CE
+98ms ║Runtime (42107 bytes) successfully initialized in 40ms (v0.3.10c.20190522) (94ms)
+99ms ║╔Execution stage started
+110ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (3ms)
+191ms ║║Condition #16 evaluated false (86ms)
+193ms ║║Condition group #1 evaluated false (state did not change) (88ms)
+205ms ║║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+207ms ║║Condition #30 evaluated true (10ms)
+213ms ║║Comparison (enum) inactive is (string) active = false (2ms)
+215ms ║║Cancelling condition #31’s schedules…
+216ms ║║Condition #31 evaluated false (8ms)
+217ms ║║Cancelling condition #29’s schedules…
+218ms ║║Condition group #29 evaluated false (state changed) (22ms)
+221ms ║║Cancelling statement #33’s schedules…
+227ms ║║Executed virtual command [Hue ambiance spot 2].wait (1ms)
+229ms ║║Requesting a wake up for Sun, May 26 2019 @ 11:12:23 PM BST (in 60.0s)
+238ms ║╚Execution stage complete. (138ms)
+240ms ║Setting up scheduled job for Sun, May 26 2019 @ 11:12:23 PM BST (in 59.991s)
+249ms ╚Event processed successfully (249ms)
5/26/2019, 11:10:53 PM +771ms
+1ms ╔Received event [Hue Motion Sensor (Hall)].motion = active with a delay of 88ms
+111ms ║RunTime Analysis CS > 30ms > PS > 42ms > PE > 39ms > CE
+114ms ║Runtime (42113 bytes) successfully initialized in 42ms (v0.3.10c.20190522) (111ms)
+115ms ║╔Execution stage started
+128ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (3ms)
+130ms ║║Condition #16 evaluated false (8ms)
+132ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+144ms ║║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+146ms ║║Condition #30 evaluated true (11ms)
+153ms ║║Comparison (enum) active is (string) active = true (2ms)
+155ms ║║Cancelling condition #31’s schedules…
+157ms ║║Condition #31 evaluated true (9ms)
+158ms ║║Cancelling condition #29’s schedules…
+160ms ║║Condition group #29 evaluated true (state changed) (24ms)
+168ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is (string) :b1145e97320e276312b238cef7c0dc4e: = true (2ms)
+170ms ║║Condition #36 evaluated true (7ms)
+171ms ║║Condition group #32 evaluated true (state did not change) (9ms)
+173ms ║║Condition group #32 evaluated true (state did not change) (1ms)
+177ms ║║Cancelling statement #37’s schedules…
+197ms ║║Executed physical command [Hue ambiance spot 2].on() (16ms)
+199ms ║║Executed [Hue ambiance spot 2].on (18ms)
+215ms ║║Executed physical command [Hue ambiance spot 2].setColorTemperature([4100]) (11ms)
+216ms ║║Executed [Hue ambiance spot 2].setColorTemperature (13ms)
+237ms ║║Executed physical command [Hue ambiance spot 2].setLevel([30]) (15ms)
+238ms ║║Executed [Hue ambiance spot 2].setLevel (18ms)
+242ms ║╚Execution stage complete. (128ms)
+244ms ╚Event processed successfully (244ms)
5/26/2019, 11:09:56 PM +425ms
+1ms ╔Starting piston… (v0.3.10c.20190522)
+185ms ║╔Subscribing to devices…
+216ms ║║Subscribing to Home.mode…
+226ms ║║Subscribing to Hue Motion Sensor (Hall).illuminance…
+236ms ║║Subscribing to Hue Motion Sensor (Hall).motion…
+291ms ║║Subscribing to Hue ambiance spot 2…
+293ms ║║Subscribing to Hue ambiance spot 1…
+294ms ║║Subscribing to Hue ambiance spot 3…
+296ms ║╚Finished subscribing (121ms)
+330ms ║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (4ms)
+345ms ║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+356ms ║Comparison (enum) inactive is (string) active = false (3ms)
+388ms ║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (3ms)
+400ms ║Comparison (enum) inactive is (string) active = false (3ms)
+410ms ║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is (string) :b1145e97320e276312b238cef7c0dc4e: = true (3ms)
+427ms ╚Piston successfully started (425ms)
5/26/2019, 11:08:20 PM +458ms
+1ms ╔Received event [Hue Motion Sensor (Hall)].motion = inactive with a delay of 62ms
+84ms ║RunTime Analysis CS > 18ms > PS > 41ms > PE > 25ms > CE
+86ms ║Runtime (42107 bytes) successfully initialized in 41ms (v0.3.10c.20190522) (84ms)
+88ms ║╔Execution stage started
+100ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (3ms)
+102ms ║║Condition #16 evaluated false (8ms)
+103ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+116ms ║║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+118ms ║║Condition #30 evaluated true (11ms)
+125ms ║║Comparison (enum) inactive is (string) active = false (2ms)
+127ms ║║Cancelling condition #31’s schedules…
+128ms ║║Condition #31 evaluated false (9ms)
+130ms ║║Cancelling condition #29’s schedules…
+131ms ║║Condition group #29 evaluated false (state changed) (24ms)
+134ms ║╚Execution stage complete. (47ms)
+135ms ╚Event processed successfully (135ms)
5/26/2019, 11:07:50 PM +490ms
+1ms ╔Received event [Hue Motion Sensor (Hall)].motion = active with a delay of 89ms
+103ms ║RunTime Analysis CS > 28ms > PS > 40ms > PE > 34ms > CE
+105ms ║Runtime (42110 bytes) successfully initialized in 40ms (v0.3.10c.20190522) (103ms)
+107ms ║╔Execution stage started
+119ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (3ms)
+121ms ║║Condition #16 evaluated false (7ms)
+122ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+134ms ║║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+136ms ║║Condition #30 evaluated true (10ms)
+142ms ║║Comparison (enum) active is (string) active = true (2ms)
+144ms ║║Cancelling condition #31’s schedules…
+146ms ║║Condition #31 evaluated true (8ms)
+147ms ║║Cancelling condition #29’s schedules…
+148ms ║║Condition group #29 evaluated true (state changed) (23ms)
+156ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is (string) :b1145e97320e276312b238cef7c0dc4e: = true (2ms)
+158ms ║║Condition #36 evaluated true (6ms)
+159ms ║║Condition group #32 evaluated true (state did not change) (9ms)
+161ms ║║Condition group #32 evaluated true (state did not change) (1ms)
+164ms ║║Cancelling statement #37’s schedules…
+184ms ║║Executed physical command [Hue ambiance spot 2].on() (16ms)
+185ms ║║Executed [Hue ambiance spot 2].on (18ms)
+201ms ║║Executed physical command [Hue ambiance spot 2].setColorTemperature([4100]) (11ms)
+202ms ║║Executed [Hue ambiance spot 2].setColorTemperature (13ms)
+223ms ║║Executed physical command [Hue ambiance spot 2].setLevel([30]) (15ms)
+224ms ║║Executed [Hue ambiance spot 2].setLevel (17ms)
+228ms ║╚Execution stage complete. (121ms)
+229ms ╚Event processed successfully (229ms)
5/26/2019, 11:06:48 PM +650ms
+221ms ║╔Subscribing to devices…
+277ms ║║Subscribing to Home.mode…
+289ms ║║Subscribing to Hue Motion Sensor (Hall).illuminance…
+301ms ║║Subscribing to Hue Motion Sensor (Hall).motion…
+374ms ║║Subscribing to Hue ambiance spot 2…
+375ms ║║Subscribing to Hue ambiance spot 1…
+377ms ║║Subscribing to Hue ambiance spot 3…
+378ms ║╚Finished subscribing (167ms)
+410ms ║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (4ms)
+425ms ║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+436ms ║Comparison (enum) inactive is (string) active = false (2ms)
+474ms ║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+484ms ║Comparison (enum) inactive is (string) active = false (2ms)
+495ms ║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is (string) :b1145e97320e276312b238cef7c0dc4e: = true (2ms)
+497ms ║Cancelling condition #36’s schedules…
+499ms ║Cancelling condition #32’s schedules…
+523ms ╚Piston successfully started (521ms)
5/26/2019, 11:02:22 PM +773ms
+237ms ║╔Subscribing to devices…
+292ms ║║Subscribing to Home.mode…
+305ms ║║Subscribing to Hue Motion Sensor (Hall).illuminance…
+319ms ║║Subscribing to Hue Motion Sensor (Hall).motion…
+409ms ║║Subscribing to Hue ambiance spot 2…
+410ms ║║Subscribing to Hue ambiance spot 1…
+412ms ║║Subscribing to Hue ambiance spot 3…
+413ms ║╚Finished subscribing (194ms)
+452ms ║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (4ms)
+467ms ║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+479ms ║Comparison (enum) inactive is (string) active = false (3ms)
+520ms ║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+531ms ║Comparison (enum) inactive is (string) active = false (2ms)
+533ms ║Cancelling condition #17’s schedules…
+543ms ║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is (string) :b1145e97320e276312b238cef7c0dc4e: = true (2ms)
+545ms ║Cancelling condition #30’s schedules…
+547ms ║Cancelling condition #19’s schedules…
+567ms ╚Piston successfully started (566ms)
5/26/2019, 10:56:37 PM +364ms
+62ms ╔Received event [Home].time = 1558907782751 with a delay of 14612ms
+1253ms ║RunTime Analysis CS > 257ms > PS > 572ms > PE > 424ms > CE
+1257ms ║Runtime (41693 bytes) successfully initialized in 572ms (v0.3.10c.20190522) (1193ms)
+1258ms ║╔Execution stage started
+2625ms ║║Executed physical command [Hue ambiance spot 2].off() (17ms)
+2627ms ║║Executed [Hue ambiance spot 2].off (20ms)
+2788ms ║╚Execution stage complete. (1530ms)
+2791ms ╚Event processed successfully (2792ms)
5/26/2019, 10:55:22 PM +596ms
+0ms ╔Received event [Home].execute = recovery with a delay of 54ms
+86ms ║RunTime Analysis CS > 27ms > PS > 40ms > PE > 20ms > CE
+89ms ║Runtime (41681 bytes) successfully initialized in 40ms (v0.3.10c.20190522) (88ms)
+90ms ║╔Execution stage started
+102ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is_any_of (string) :302bcc01d8fc7d79826d917e0169f855:,:4741a60e498c1b32b57b46dfce8e2ee0: = false (2ms)
+104ms ║║Condition #16 evaluated false (7ms)
+105ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+113ms ║║Comparison (string) :b1145e97320e276312b238cef7c0dc4e: is (string) :b1145e97320e276312b238cef7c0dc4e: = true (2ms)
+115ms ║║Condition #18 evaluated true (6ms)
+116ms ║║Condition group #17 evaluated true (state did not change) (8ms)
+128ms ║║Comparison (integer) 0 is_less_than_or_equal_to (integer) 10 = true (2ms)
+130ms ║║Condition #20 evaluated true (11ms)
+139ms ║║Comparison (enum) inactive is (string) active = false (2ms)
+141ms ║║Condition #21 evaluated false (10ms)
+142ms ║║Condition group #19 evaluated false (state did not change) (23ms)
+146ms ║║Cancelling statement #29’s schedules…
+152ms ║║Executed virtual command [Hue ambiance spot 2].wait (1ms)
+154ms ║║Requesting a wake up for Sun, May 26 2019 @ 10:56:22 PM BST (in 60.0s)
+164ms ║╚Execution stage complete. (75ms)
+166ms ║Setting up scheduled job for Sun, May 26 2019 @ 10:56:22 PM BST (in 59.99s)
+176ms ╚Event processed successfully (175ms)
5/26/2019, 10:51:32 PM +924ms
+10086ms ║Piston waited at a semaphore for 10024ms
