So that should tell you that the GE switch is at fault. GE/Jasco Dimmers I have found are not very good with the LED lighting. SInce Phillips allows you to adjust brightness why not move the Switch to another area of the house and replace it with an Non-Dimming switch. That should solve your problem, It did for me and my friend.
