Has anybody had experience connecting a Philips Hue Flushmount Light to SmartThings? I attempted to pair it, it immediately showed up as a thing, but says “Can’t connect to the decice” when I click on it. Has anyone had a similar experience? Any tips or thoughts?
It’s just listed as a thing—I’m assuming it needs to be listed as a ZLL Dimmer Bulb, but I’m not sure how to make that change. It’s functionally a Hue light strip.
In your IDE, you can edit the device to use whatever device type you want.
Open up the device, go to Edit at the bottom, and change the Type in the dropdown box. Hit update.
