Can I use the Philips Hue White A19 Single Bulb (455295) with smartthings only (no philips bridge)? I do not want anything fancy, just to turn them on and off via APP.
It can be done technically, but it is not recommended or supported. You could end up with a bulb that you cannot transfer back to Hue bridge without needing an additional device.
They added in the normal way. i.e. set app to âAdd A Thingâ. I did have trouble in the early days with the DH that was allocated to them so downloaded this DTH and used it.
Improved Zigbee Hue Bulb MA
Not sure if this is the best one but it works OK for me. If you want to use it do a search and you should find it OK.
Yea I saw these posts, just wanted to know if anyone out there was using this bulb with ST (successfully). I know that once its on ST its not coming off without a fight! Again, just looking for simple on and off. I do not plan on getting a bridge.
I have a few of the GE link bulbs but I can not find them anywhere!!
@JDRoberts thanks again, Im going thru the thread you posted before and see that now. I just need to find the correct device handler for this model. (I can see this is a hot topic!) LOL
Been trying to add philips hue white bulb to ST without bridge. Been reading around. Could you tell me which DH to use? I used the one from Jason Steele but not working. ST not showing the bulb as a thing. Any ideas?
Has the bulb been previously paired to a Hue Bridge?
If so it needs to be reset to factory default settings first.
This can be done via the bridge or with a Phillips remote.
i have a hue light strip. i connected it directly to smartthings with no hue bridge. (this is not recommended but didnt want to buy a bridge.) you have to add a device hander.
