Philips Hue Bulbs and Smart Lights Dim Issue
I’ve got some Philips Hue White and Color Ambiance bulbs along with a 3rd gen Philips Hub setup in SmartThings. Bulbs were all automatically setup as ZLL RGBW Bulb device type. I can change the color and dimmer level using the SmartThings app, no problem. But when I use the Smart Lights smartapp and the option ‘Turn On & Set Color’, the system appears to ignore the dimmer level. It sets the color correctly, but leaves the dim level. I’ve tried using a couple of different device handlers, but still no luck.
Is anyone using the Philips hub integration able to get the bulbs to change color AND set dim level using the Smart Lights ‘Turn On & Set Color’ feature?
